Thread: Heater/Blower packed in Help please!!!!
  1. Heater/Blower packed in Help please!!!!
    May 2009
    England
    Hi ever since this bad cold weather has started my heater/blower has stopped working all together, does anyone no what it could be does something need replacing or do i need to wait untill it gets abit warmer for a part to kind of thaw out, i no there is aready a post further down about this but ive read that and had no luck i could do with getting it fixed fast because i cant clear my windows and drive anywhere, thanks
  2. Re: Heater/Blower packed in Help please!!!!
    Dec 2009
    Yeovil
    Had the same problem myself this week. After removing the fan from its housing i noticed that the red cable (connected to the resistor pack) had burnt out meaning heavy resistance to the fan. I removed the resistor pack, cleaned the connector, replaced the connector on the fan side and all works fine!
    Just for info, if you remove the red cable from the resistor pack, you should get about 6 Volts with your fan set to 4....give that a go befor you replace the fan.
    I took my fan to work and put a 6 Volt battery across it...it worked fine.
    Hope this helps
  3. Re: Heater/Blower packed in Help please!!!!
    Nov 2012
    Middle of England
    Ancient thread revival for the win.
    So I have a Mk3 Golf estate & the fan stopped working but I could still feel Hot air coming through. After a Google search I found a few threads on here but this one solved my issue as my Red wire had also corroded/burnt out a bit. Really easy to access on the Mk3 with just pulling a bit of lining out the way & popping a couple of clips. Gave the terminals a good scrape & clean & I now have a fully working fan again.
    So Thanks to adrian.wilkes as you've just saved me a few quid & Thanks to whoever is hosting the forums, I'll do the rest in an intro thread, Not new to forums.
  1. Heater/Blower stopped working
    By scottjay86 in forum Golf MK3 - 1993 - 1999
    Last Post: 26-02-2010, 12:10 AM
  2. Question 2007 Passat radio packed up - twice!
    By aquitiane in forum New Member Introductions
    Last Post: 01-10-2009, 10:22 AM
  3. VW polo packed up?
    By kazzaman in forum Polo - Derby - Lupo - Fox
    Last Post: 24-09-2009, 03:10 PM
  4. Polo packed up?
    Last Post: 06-07-2008, 04:30 AM
  5. Wipers Packed Up
    By jonnyboy595 in forum Early Passat Forum - Pre 97
    Last Post: 05-05-2007, 09:54 AM
