Thread: Help!!Rear Washer A6 Avant
  1. Help!!Rear Washer A6 Avant
    Dec 2009
    London
    Hi..
    I have recently purchased an A6 Avant, All is good howeverthe rear washer jet seems to be working but there is no water coming out of the nozzle...
    Tests later,i.e small pin in to the jet and still nothing, then stripped the compartment where the CD changer is normally housed and found my latest addition to the the A6 which i never knew had. A Fish tank... Long story short, Water drained and hose re-connected..
    Started again thinking this had cured the problem.
    To my dissapointment it hasn't however and i now have a soaked boot lid...
    Can any one advise or guide me on how to reslove this issue. If anyone can advise on how to remove the boot lining it would be greatly appreciated.
    Thanks in advance...
  2. Re: Help!!Rear Washer A6 Avant
    Mar 2008
    High Wycombe
    I think there's a join in the hose near the CD changer, and it sounds like yours has popped off.
    There's another post a couple below this one with the same problem.
    link here
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  3. Re: Help!!Rear Washer A6 Avant
    Behind the wiper itself there is a bit of pipe and its metal and that might of corroded and then leak in the back of the tailgate instead. Im sure its above the warning triangle. Find this pipe then get someone to press the washers and see if it leaks..
  1. The New Audi A6 All Road, at home on all roads and tracks
    Last Post: 29-04-2006, 06:00 PM
  2. At home on all roads and tracks - Audi A6 allroad quattro
    Last Post: 05-03-2006, 07:53 PM
  3. New Audi A6 Avant Range Update
    Last Post: 20-01-2005, 10:34 PM
  4. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
  5. Ultimate specification for A6 Avant final edition models
    Last Post: 18-10-2004, 07:29 PM
