Thread: GT TDI 130 - Windscreen fogging & icing
  1. GT TDI 130 - Windscreen fogging & icing
    Dec 2009
    London UK
    Hi all.
    I seem to be constantly struggling with the windscreen on my golf fogging up and have found the inside of the windscreen to be iced up on these recent cold mornings. I usually have the air-con turned on if there's a hint of moisture in the air and I don't recall having to do this with any of my previous cars.
    Is this normal?! I was wondering if the door seals need replacing of the vents clearing out or something?
    Any help much appreciated.
    Cheers!
  2. Re: GT TDI 130 - Windscreen fogging & icing
    Check the pollen filter and check the recirculation flap mptpr
  3. Re: GT TDI 130 - Windscreen fogging & icing
    Dec 2009
    London UK
    Thanks - what am I checking the pollen filter for? Blockages?
    What and where is the recirculation flap?!
  4. Re: GT TDI 130 - Windscreen fogging & icing
    The pollen filter can be damp or full av crap, The recirculation flap motor is behind the glove compartment,it is part of the AC system.If the flap motor fails in the recirculating position,there will be no fresh air flow to the interior of the vehicle,which results in the windows steaming up.You can get a fault code read which may verify a fault with the unit
  5. Re: GT TDI 130 - Windscreen fogging & icing
    Southampton, UK.
    Have you checked whether the carpets are dry?
    2003 VW Golf Est 1.9 TDI 130
    2006 Audi A3 2.0 TDI Sport 140
  1. Please Help Best Golf for £10k and confusion over different engines?
    By deshg in forum Golf MK5 - 2004 - 2009
    Last Post: 21-09-2010, 07:47 PM
  2. Please can someone help
    By Daz9048 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-07-2009, 08:34 AM
  3. Volkswagen launches new range of highly efficient golf models
    Last Post: 03-07-2009, 07:48 PM
  4. Will a 54 plate tdi 130 turbo fit a 51 plate 130 tdi???????????
    By wasabi in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-06-2007, 05:27 PM
  5. New 2.7 TDI Model boosts Audi A6 Saloon range
    Last Post: 24-11-2004, 09:00 PM
