Thread: Mk4 115bhp TDI : Dual Mass Flywheel & Clutch
  1. Mk4 115bhp TDI : Dual Mass Flywheel & Clutch
    Sep 2009
    chester
    Folks.
    Again, I appreciate this is a post most probably asked a thousand times before. I've got a 115 TDi, with 146k on the clock. It's been pretty ace since I bought it, but now the clutch is beginning to slip. I appreciate it's still seemingly early days in the clutch slipping department, but the car is on the original clutch and DMF.
    If I end up replacing the clutch, has anyone got any realisitic figures on cost of replacement? (Is £450 - £500 realistic?). I'm looking for a VW indepdenent specialist rather than main dealer? And also, should I get the dual mass flywheel replaced at the same time while the gearbox / engine are separated. If so, any thoughts on cost for this as well? Does anyone have any similar experiences, before I end up spending up to £800 on such a high miler.
    I'm sure it's something thats probably been asked a million times before, anyone got any experiences in this department for a similar spec car?
    All help appreciated!!!
  2. Re: Mk4 115bhp TDI : Dual Mass Flywheel & Clutch
    May 2007
    Little Houghton, Barnsley, United Kingdom, United Kingdom
    Does the clutch slip all the time?
    I know it sounds daft but if it is not doing it all the time then it could be something leaking into the clutch area as i have heard the problem a few times but as for the price £800 sounds about right for flywheel and clutch
  3. Re: Mk4 115bhp TDI : Dual Mass Flywheel & Clutch
    Sep 2009
    chester
    aha. interestingly, or at least, i think it doesnt. it has little blips where the revs rise. but 70mph is pretty much spot on 2000 revs in sixth gear, so i think its only slipping occasionally on acceleration.
    i read about the `minor slips due to diesel / oil leakage` elsewhere, and thus could do with learning more for certain, if anyone has any pointers?
  1. Dual Mass Flywheel Problem
    By nickb_2008 in forum Golf MK5 - 2004 - 2009
    Last Post: 30-03-2008, 01:56 AM
  2. Dual mass flywheel and Clutch
    By nano in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-01-2008, 08:38 PM
  3. Dual Mass Flywheel Fault?
    By TDiBoraSam in forum Bora - 1998 - 2005
    Last Post: 02-09-2007, 07:43 PM
  4. Golf Mk4 TDI 130 Clutch Replacement
    By gavbarlow in forum Golf MK4 - 1999 - 2004
    Last Post: 23-08-2007, 12:47 PM
  5. Audi takes pole position in TDI diesel development
    Last Post: 01-04-2006, 07:34 PM
