Thread: Vag com error 01206
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: Vag com error 01206
    1834 Post(s)
    There is also a drain under the battery tray that needs to be cleaned after the tray has been removed.
  2. Re: Vag com error 01206
    Tullamore, Ireland
    Hi Guys,
    Anyone got any ideas on my radio problem? See problem below. And its a Chorus, not a Concert!
    "2. There is not a kick out of my radio (concert 1 I think). Tried using vagcom to test it but got no response from controller. Checked fuses in the fuse box on drivers side and nothing is blown. Anybody got any ideas? Are there more fuses that I don't know about - possibly behind the radio?"
    Cheers guys.
  3. Re: Vag com error 01206
    Tullamore, Ireland
    Hi Folks,
    Fixed my stereo, there was a blown fuse in the back of it.
    Last problem now is my ESP light coming on and staying on. I ran vagcom and the steering angle sensor was showing a fault. Under measuring block 005 the steering angle is showing 12.5 when straight (should be -5 to +5). Had the instructions with me to reset the steering angle sensor but it stays at 12.5. Its the original slipring that I took out of the car that is back in it now.
    Anyone any thoughts?
    Thanks.
  4. Re: Vag com error 01206
    Tullamore, Ireland
    Ignore my last post - I just read the "ESP light ARRRRGH" post. It seems to give a lot of info.
  5. Re: Vag com error 01206 - Update
    Apr 2012
    bradford
    Quote Originally Posted by fulcrum111 View Post
    Hi Guys,
    Just to give an update. I bought a new battery yesterday to have just in case. Jump started the car at work, drove home. Turned off the engine and it wouldn't start again. Checked the voltage in the battery - it was about 12.3 and it dropped to about 11.4 after trying to turn over the engine again. Decided to change the battery. The battery I removed was an original Audi supplied battery - had the 8E0 PN printed on top. I wonder was this the original battery supplied with the car 6 years ago? Would a battery last that long?
    Anyway, installed the battery and the car started fine. Went for a quick drive to give it a bit of charge. Left it over night and started it again this morning wth no problem, so I'm assuming there is no drain and that it was the old battery giving up the ghost!
    2 problems I now have are:
    1. ESP light came on this morning on the way to work, intermittantly at first going around bends and then it came on full. Ran vagcom and the steering angle sensor was showing a fault. Under measuring block 005 the steering angle is showing 12.5 when straight (should be -5 to +5). Had the instructions with me to reset the steering angle sensor but it stays at 12.5 - possible faulty slipring??
    One interesting think I found when I took out the battery was that the compartment underneath was full of water! There is a drain hole over towards the drivers side which was completely blocked up. I cleared that and most of the water drained away. I noted a rubber oblong stopper sitting right underneath the battery - anyone know what this is for. Should I remove it to help drain water also?
    Oh yea, I still have the 01206 fault in controller 08 - Auto HVAC.
    Anyone got anymore suggestions or comments re. the above points?
    Thanks all!
    I have the 01206 error code too in my a4... did you manage to fix it?
  6. Re: Vag com error 01206 - Update
    Sep 2020
    Coventry
    Quote Originally Posted by wheymonster View Post
    He asked for all that help and got it, as soon as someone asked him for help, you hear nothing from him. They only act nice and friendly when they're after something. Won't return the favour though will they? Terrible
  1. The best VAG vehicle
    By Crasher in forum Chat - Completely Off Topic
    Last Post: 24-08-2009, 11:59 AM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. vag 1551 tool or vag com
    By Paul C in forum Golf MK3 - 1993 - 1999
    Last Post: 09-12-2007, 03:50 PM
  4. Are And Vag Com / Vag Tacho The Same
    By davecoz in forum VCDS - General Questions
    Last Post: 21-11-2007, 09:13 AM
  5. cam belt interval
    By lucifer in forum Audi A4 - Archive Topics
    Last Post: 29-01-2007, 07:12 PM
