Thread: Audi Drive Select
  1. Audi Drive Select
    Feb 2007
    Hello, thinking of changing from a b7 s-line to a b8 - our roads aren't built to Teutonic standards and the quality of the suspension is at odds to the quality of the interior.
    Was wondering if anyone knows; is the suspension of an s-line with adaptive suspension the same as an SE with adaptive suspension (have seen it written that SE drops 20mm when ADS added).
    If yes, then the ride quality should be the same, right??
  2. Re: Audi Drive Select
    Apr 2009
    Sydney
    ADS uses the same springs as S-Line (with 20mm drop), but the damping rates are very different. The ADS "comfort" setting has a much softer damper rate than a standard S-Line, while the ADS "dynamic" setting is stiffer for low speed movements, but softer than S-Line at the high speed end (that is, large bumps!) So an ADS equipped car should be more comfortable that an S-Line for both settings, with softer handing in comfort mode and better handling in dynamic mode. I find it an excellent piece of kit, and on 245/40x18 tyres, its very comfortable in comfort mode.
  3. Re: Audi Drive Select
    Feb 2007
    I thought nobody cared........thanks..................
    Given that ADS uses S-line springs, as per original question, I guess then that there is no difference in ride quality between SE and Sline if both have ADS???????
  4. Re: Audi Drive Select
    Jan 2009
    Essex
    Be very careful with terminology :
    The S-line gets "Sports" suspension (20mm drop) as standard.
    The "S-line" suspensions (30mm drop) is an option.
    I can't answer your question but I've an S-line with ADS and it's a perfect combination of everything ......for me at least
    MY2010 A4 Avant 2.0 TFSI quattro S-line Exec - Aruba Blue, 19" alloys, Full Leather, B & O, 3G Tech Pack, Adaptive Lights, Dynamic Susp, Folding Mirrors, Power tailgate, Storage/Light Packs, Parking Plus, Heated Seats, Rear Blinds, Load Rails, Privacy Glass, Rear Airbags, TPMS, Load Liner
    Gone : 09 A4 Avant, B6 S4, TT, Golf GTi...and the rest are embarassing!
  5. Re: Audi Drive Select
    Apr 2009
    Sydney
    Quote Originally Posted by willie1973 View Post
    Correct, providng we're talking about the 20mm drop S-Line suspension.
  1. Vast 35-metre audi ‘monument’ takes centre stage at goodwood
    By stuart in forum "How To" Guides - Vehicle Related
    Last Post: 03-07-2009, 07:53 PM
  2. The new Audi Q5: Sporty and versatile
    Last Post: 19-04-2008, 02:25 PM
  3. a4 multitronic problem
    By a4god2ulot in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-09-2007, 02:52 PM
  4. How does the Quattro system work?
  5. Audi TT Shows its True Colours
    Last Post: 13-06-2007, 07:57 PM
