Thread: login codes needed for new abs pump coding
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
  1. login codes needed for new abs pump coding
    Aug 2008
    i have just fiitted a new abs pump to a 2003 audi a6 2.5 tdi auto tiptronic with esp, i need to code the module on the abs pump with vcds (genuine and registered) but i can't seem to login with the codes that i have 09497.
    i have managed it once but i coded the abs with codes for an a4 instead of the a6. i also need to set the steering angle, again have tried but with no joy. i have a scan listed if this helps.
    Friday,27,November,2009,18:02:48:24293
    VCDS Version: Release 908.1
    Data version: 20091018
    Chassis Type: 4B - Audi A6 C5
    Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
    76 77
    VIN: WAUZZZ4B14N020146
    Address 01: Engine Labels: 078-907-552-AMM.lbl
    Part No: 3B0 907 552 BK
    Component: 2.4L V6/5V 0002
    Coding: 11582
    Shop #: WSC 00443
    WAUZZZ4B14N020146 AUZ7Z0C2422692
    No fault code found.
    Readiness: 0110 1001
    Address 02: Auto Trans Labels: 01J-927-156.lbl
    Part No SW: 4B0 910 155 G HW: 01J 927 156 HH
    Component: V30 01J 2.4l 5V RdW 3120
    Revision: 00000004 Serial number: 00000000425129
    Coding: 0000001
    Shop #: WSC 00618 210 60461
    Address 03: ABS Brakes Labels: 4B0-614-517.lbl
    Part No: 4B0 614 517 G
    Component: ABS/ESP front 3428
    Coding: 00000
    Shop #: WSC 00000
    2 Faults Found:
    00778 - Steering Angle Sensor (G85)
    66-10 - Not Matched - Intermittent
    01044 - Control Module Incorrectly Coded
    35-00 - -
    Address 08: Auto HVAC Labels: Redir Fail!
    Part No: 4B0 820 043 AR
    Component: A6-Klimavollautomat 0208
    Coding: 00001
    Shop #: WSC 00618
    Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
    Part No: 4B0 959 655 P
    Component: Airbag 8.4EP 3002
    Coding: 0001106
    Shop #: WSC 02325 785 00200
    Address 16: Steering wheel Labels: 4B0-907-487.lbl
    Part No: 4B0 907 487 H
    Component: Lenkradelektronik D01
    Coding: 01012
    Shop #: WSC 02335
    1 Fault Found:
    01426 - Controls in Steering Wheel (E221)
    49-00 - No Communications
    Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
    Part No: 4B0 920 981 K
    Component: KOMBI+WEGFAHRS. VDO D12
    Coding: 00462
    Shop #: WSC 00198
    Address 35: Centr. Locks Labels: 4B0-962-258.lbl
    Part No: 4B0 962 258 N
    Component: Zentralverrieg.,DWA D38
    Coding: 04939
    Shop #: WSC 00443
    Address 45: Inter. Monitor Labels: None
    Part No: 4B0 951 178 A
    Component: Innenraumueberw. D04
    Coding: 00102
    Shop #: WSC 02335
    Address 56: Radio Labels: None
    Part No: 4B0 035 195 R
    Component: symphony II NP2 0152
    Coding: 02005
    Shop #: WSC 00618
    Address 76: Park Assist Labels: 8E0-919-283-8E2.lbl
    Part No: 8E0 919 283
    Component: Parkingsyst. A6 RDW D09
    Coding: 01116
    Shop #: WSC 02335
    End -----
  2. Re: login codes needed for new abs pump coding
    Sep 2009
    Apollo
    This should get you going:
    http://wiki.ross-tech.com/index.php/...28Bosch_5.7%29
    You will need to create a login based on the PR data listed, and the label in your trunk or owners manual.
    Example: http://www.ross-tech.net/vag-com/mis...s/PR-Codes.png
    Then in the same session, without exiting ABS module or cycling the key off:
    Code the module
    Set G85 Basic settings
    If this still doesn't make sense, post a pic of the vehicle ID tag and we will find the login and coding.
  3. Smile Re: login codes needed for new abs pump coding
    Aug 2008
    thanks for that, but still a bit confussed with working out the coding. i have listed below what is on the code sticker in the rear of the car:-
    1593 30-4-2249 210 en
    wauzzz4b14n02146
    a6 avant 2.4 v6
    125kw a6m
    bdv ghk
    lz9w/lz9w n1h/lg
    0GG 4UF 6XD 5SJ 6TS
    J0L 1LT 1BE
    5TM 7X2
    8GL OG7 0YE 0JJ
    3NZ 8JK U1D X2B 1N3
    2ZS 3HA 8Q1 9Q2 8Z5 D5B
    7QO C9V 7K0 4X1 VJ1 6R0
    3PF 4KC 3Y0 4K4 5D1
    1SA Q1A 4GP
    1638 14.3 7.1 9.7 233
    it would be a masive help if you can work this out for me.
    thanks in advance, deutsch
  4. Re: login codes needed for new abs pump coding
    May 2007
    knee deep in clunge
    14 Post(s)
    07399
    0=0
    7= a6
    3= 1lt 16 inch front brakes
    9= 6 cylinder petrol
    9= mulititronic
  5. Re: login codes needed for new abs pump coding
    Sep 2009
    Apollo
    As a8 tech responded (and I figured as well):
    Login 07399
    Coding 06499
    Then do the G85 Basic settings listed at the bottom of page:
  6. Re: login codes needed for new abs pump coding
    Aug 2008
    thanks for that, all coded in and working now.
    just one more fault to figure out, tiptronic and radio controls on steering wheel are not working, no communication. same codes as listed earier in the thread.
  7. Re: login codes needed for new abs pump coding
    May 2007
    knee deep in clunge
    14 Post(s)
    check measured value blocks 1 and 3 for switch operation status in address 16
    1 = volume and radio station
    3 = tiptronic
    If no change check the wiring or replace j453
  8. Re: login codes needed for new abs pump coding
    Feb 2012
    australia
    hello, a8 tech and dana.
    i have a similar problem with a dash in a 2000 golf.
    I have a solus pro and the helpfull team here in australia say that a login code is strictly a dealership thing.
    so i asked spencer who i usually deal with in parts at my local and he says i cant get it over the counter unlike a stereo code.
    if its not too much a pain, could you explain how you did this? i read the ross tech pages you listed and cant figure it out?
    you mentioned "You will need to create a login based on the PR data listed, and the label in your trunk or owners manual."
    cheers bj
  9. Re: login codes needed for new abs pump coding
    Sep 2009
    Apollo
    Quote Originally Posted by the sherrid View Post
    cheers bj
    I'm sure you have this resolved already but the Mk4 Golf (and similar) use Mk20 and Mk60 ABS systems which do not involve a Login like the Bosch family modules. Instead, the ABS coding is either built from scratch as listed in the Wiki or by using the factory repair manual which may refer to ABS generation and part number in combination with the engine and transmission code(s).
    -Dana
  10. Re: login codes needed for new abs pump coding
    Feb 2012
    australia
    hello dana,
    thanks for your reply,
    its actually the dash i need a login code for. When i plug my snapon scan tool into it, the solus pro, which i have already spoken to the snap on helpline about and they agree that a login code is needed.
    since my last post, i had purchased a vag-com cable from www.vag-diagnostics.com.
    unfortunately i still havnt recieved it as it has been lost in the mail so i'm still waiting on it. Some feed back if your interested in it or not, i actually tried the australian dealer in boroia melbourne for the ross tech cable however after calling and leaving a message twice he failed to get back to me at all so i went for what i thought was the second most reliable manufacturer.
    however as a tech guy that just wants to know, i'd still like to know how to do it.
    anyone?
  1. A6 (C5) 1.9 PD TDI Oil Change with Pella
    By Col in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-10-2009, 09:43 PM
  2. Please Help 1997 A3 1.6 Sport ABS HELP URGENT
    By hydroxicut in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 01-08-2009, 09:24 AM
  3. 1.9 PD TDI Oil Change with Pella
    By Col in forum General
    Last Post: 21-07-2009, 07:56 PM
  4. Central Locking Pump Needed
    By Moonkiss in forum 100 - 200 - Turbo - 100 S4
    Last Post: 06-01-2007, 02:45 AM
  5. Problem with ABS on Polo 2001 1.4L
    By lyonelk in forum Polo - Derby - Lupo - Fox
    Last Post: 12-08-2006, 09:08 AM
