Thread: login codes needed for new abs pump coding
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 40
  1. Re: login codes needed for new abs pump coding
    #21
    May 2007
    17 Post(s)
    Quote Originally Posted by Educlass2012 View Post
    Hi wanted to let you know I did 1 typo
    i had entered "702" but the proper digits should be "7Q2" (3rd line to the bottom left)
    will that have made a difference?
    No, that code (7Q2) isn't relative to the ABS coding.
    also I really really appreciate your help!!!! FLASH2 - Jim!!
    Your welcome.
    could you possibly teach me how you came up with the codes?
    Maybe you should make sure they work for you first. It's possible I've completely misunderstood the info on the Ross-tech web site.
    Jim.
  2. Re: login codes needed for new abs pump coding
    #22
    Nov 2014
    United Kingdom
    sorry to jump on your post but getting desperate now , have problem with abs unit on 05 octavia it,s an mk70 pump , visited ross tech and using vag . com got the code for this pump as ... 0016384 but wont accept code ! will take code 0000000 but this trys to activate tyre pressure monitors ( that i dont have ) any way to generate another code ??
  3. Re: login codes needed for new abs pump coding
    #23
    May 2007
    17 Post(s)
    If you still have the original ECM, can't you plug it back in and read the coding from that?
    You didn't post the vehicle data required to work out what the code should be so we can't confirm if the one you have is correct or generate another one.
    Jim.
  4. Re: login codes needed for new abs pump coding
    #24
    Nov 2014
    United Kingdom
    Quote Originally Posted by Flash2 View Post
    Jim.
    hi jim thank you for your reply , what i think i have done is i replaced the complete pump and i guess the car stored the code from the 2nd hand part then i removed the pump and fitted the original ecm to the 2nd hand block fitted it back on the car now the pump wont activate to bleed so guess its the coding power supply etc all ok is it a copy of the car data tag as earlier you require ? many thanks garry
  5. Re: login codes needed for new abs pump coding
    #25
    Nov 2014
    United Kingdom
    Quote Originally Posted by garylangley View Post
  6. Re: login codes needed for new abs pump coding
    #26
    Nov 2014
    United Kingdom
  7. Re: login codes needed for new abs pump coding
    #27
    May 2007
    17 Post(s)
    You work out the code like this :
    Model = 0000001
    Suspension = 0000640
    Tyre Pressure Monitor = 0016384 (I don't see the PR code (7K?) on the data sticker but given the code you already tried, I guessing the car doesn't have it.)
    From Ross-Tech web page : "Coding is the sum of the individual options." , so now you just add all those number together to get the code = 0017025
    1 1 0
  8. Re: login codes needed for new abs pump coding
    #28
    Nov 2014
    United Kingdom
    thanks a million guys , guide to working out the code superb but unfortunately for me that's the code the pump has on it and its not working ... time for the car to head to a dealership think
  9. Re: login codes needed for new abs pump coding
    #29
    May 2007
    17 Post(s)
    Maybe if you tell us what the original fault was we could offer some input?
  10. Re: login codes needed for new abs pump coding
    #30
    Nov 2014
    United Kingdom
    hi again abs not working fault code read as pressure switch sporadic when first scan was ran ,hydraulics side of abs pump replaced bled etc and now showing code 01276 sure code 01276 points towards a power supply fault will have to investigate wiring as im sure the coding is now correct
  1. A6 (C5) 1.9 PD TDI Oil Change with Pella
    By Col in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-10-2009, 09:43 PM
  2. Please Help 1997 A3 1.6 Sport ABS HELP URGENT
    By hydroxicut in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 01-08-2009, 09:24 AM
  3. 1.9 PD TDI Oil Change with Pella
    By Col in forum General
    Last Post: 21-07-2009, 07:56 PM
  4. Central Locking Pump Needed
    By Moonkiss in forum 100 - 200 - Turbo - 100 S4
    Last Post: 06-01-2007, 02:45 AM
  5. Problem with ABS on Polo 2001 1.4L
    By lyonelk in forum Polo - Derby - Lupo - Fox
    Last Post: 12-08-2006, 09:08 AM
