Thread: login codes needed for new abs pump coding
Results 11 to 20 of 40
  1. Re: login codes needed for new abs pump coding
    Ambler, PA, USA
    Quote Originally Posted by the sherrid View Post
    hello dana,
    since my last post, i had purchased a vag-com cable from [A cloner] .
    That will end our assistance... Good luck. Those who buy clones are not people we will support.
  2. Re: login codes needed for new abs pump coding
    Feb 2012
    australia
    Quote Originally Posted by bearthebruce View Post
    yeah thanks for that bruce.
    open to anyone:
    I am simply interested to know how to generate one, i followed the suggested method however it doesn't work in my case. (see reply by dana) i understand that it depends on he specifics of the car however has someone written a more comprehensive procedure?
    I actually don't need a login code anymore thanks to my clone friends at snapon however as a coder i just want to know how to do it!
  3. Re: login codes needed for new abs pump coding
    Apr 2013
    Poole,UK
    Hi Guys
    Im trying to generate login code to reprogram my new ABS pump but its not working for me.
    I have went to ross-tech wiki website and Im doing everything step by step but I cant get working login.
    Can someone help me with this please? Im wery close to give up and sell the car...I have changed control module,all four sensors,abs rings and breaking pad.Just have enough at this point.
    Please can someone help me generate that code?
  4. Re: login codes needed for new abs pump coding
    Feb 2012
    australia
    at the risk of unknowingly offending the above. I can suggest the method that worked for me however only outside of the forum. One thing i can tell you is that, vcds it'self doesn't generate it for you.
  5. Re: login codes needed for new abs pump coding
    Apr 2013
    Poole,UK
    gregwaterloo@yahoo.co.uk
  6. Re: login codes needed for new abs pump coding
    Feb 2012
    australia
    Quote Originally Posted by Gregigregi View Post
  7. Re: login codes needed for new abs pump coding
    #17
    Aug 2008
    please can you pm me how you managed to do the login code???
  8. Re: login codes needed for new abs pump coding
    #18
    Nov 2014
    Hampton
    Quote Originally Posted by a8 tech View Post
    07399
    0=0
    7= a6
    3= 1lt 16 inch front brakes
    9= 6 cylinder petrol
    9= mulititronic
    Hi can you please help me figure my information too:
    waull44e15n001263
    4e2 51L 2523531
    a8 Lim. Quat 4.2 V8. 06/04
    246kw. A6
    BFM. Eyd hhv
    Ly7Q / LY7Q. NSD / LF
    E0A OGM 4UH 6XL 5SG 5RW
    1KW JOZ 1LL. 1BK
    3FE. 5MG 7X2
    F0A. 0YZ 0JZ
    T81. 8ED U1B X9A
    2ZM. 8Q0 8Z6 D0G
    702. CL7 7k3 2k2
    3PN. 4kc 3y5. 4k7.5d2
    5Z0 Q2J. 4GP
  9. Re: login codes needed for new abs pump coding
    #19
    May 2007
    17 Post(s)
    From your supplied info I get :
    Login : 05297
    Coding : 0008597
    Jim.
  10. Re: login codes needed for new abs pump coding
    #20
    Nov 2014
    Hampton
    Hi wanted to let you know I did 1 typo
    i had entered "702" but the proper digits should be "7Q2" (3rd line to the bottom left)
    will that have made a difference?
    also I really really appreciate your help!!!! FLASH2 - Jim!!
    could you possibly teach me how you came up with the codes? I have been trying to understand how the process goes. I went to Ross-tech but the codes would have come up different than what you gave me.
    Thank you so much again for your time and knowledge!!!!
  1. A6 (C5) 1.9 PD TDI Oil Change with Pella
    By Col in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-10-2009, 09:43 PM
  2. Please Help 1997 A3 1.6 Sport ABS HELP URGENT
    By hydroxicut in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 01-08-2009, 09:24 AM
  3. 1.9 PD TDI Oil Change with Pella
    By Col in forum General
    Last Post: 21-07-2009, 07:56 PM
  4. Central Locking Pump Needed
    By Moonkiss in forum 100 - 200 - Turbo - 100 S4
    Last Post: 06-01-2007, 02:45 AM
  5. Problem with ABS on Polo 2001 1.4L
    By lyonelk in forum Polo - Derby - Lupo - Fox
    Last Post: 12-08-2006, 09:08 AM
