Thread: 1.9 TDI PD 130 what oil???
Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
  1. Re: 1.9 TDI PD 130 what oil???
    #21
    May 2006
    Redruth, United Kingdom
    when cold, a 5w-40 will flow at roughly the same rate as a 5w-30. When at 100C, the 5w-30 will be a bit thinner
  2. Re: 1.9 TDI PD 130 what oil???
    #22
    Nov 2006
    Manchester
    Quote Originally Posted by oilman View Post
    Thanks for that. So its not total disaster if both are mixed? Thinner means it gets to more parts of the engine for longer?
  3. Re: 1.9 TDI PD 130 what oil???
    #23
    May 2006
    They're fine to mix and due to it only being a litre, isn't going to make much difference at all
  4. Re: 1.9 TDI PD 130 what oil???
    #24
    a4suction Guest
    5 40 pd oil for me all the way... Annual service but I dunno what the mileage is set to, roughly 10k methinks. Took her off the longlife program when I had her 2 years ago when she was @ 75k, currently 120 plus now and going fine.
  5. Re: 1.9 TDI PD 130 what oil???
    #25
    May 2006
    PD spec oil, regular changes and you cannot go wrong really
    Guy
  6. Re: 1.9 TDI PD 130 what oil???
    #26
    Oct 2019
    Finland
    Quote Originally Posted by skartsocket View Post
    I have a B6 1.9TDI PD 130,
    What grade oil does everyone recommend for engine oil changes?
    Castrol edge 5w30 LL and change it after 10k.... The engine will last forever 502.00 and 505.00 and 505.01 is the specs the specs 507.00 is good eather do not make mistake like meny are doing... Don't change the oil in PD engine after 15...20k...... It will resolt in injector, camshaft and hidrolic lifter damage......
    Sent from my FIG-LX1 using Tapatalk
  7. Re: 1.9 TDI PD 130 what oil???
    #27
    May 2012
    Everywhere
    308 Post(s)
    1 1 0
  8. Re: 1.9 TDI PD 130 what oil???
    #28
    Oct 2019
    Finland
    Quote Originally Posted by Gazwould View Post
  1. What oil should I use - 04 Passat 130 1.9 TDi
    By TeaTimeGilly in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-05-2016, 06:09 PM
  2. Audi covers new ground with 2010 q7 suv
    Last Post: 15-04-2009, 08:08 PM
  3. Answers From The Oil Expert
    By oilman in forum Archive posts
    Last Post: 05-10-2007, 03:25 PM
  4. Replies: 0
    Last Post: 20-07-2006, 09:08 PM
