Thread: 1.9 TDI PD 130 what oil???
Results 11 to 20 of 28
  1. Re: 1.9 TDI PD 130 what oil???
    Jul 2009
    Belgium
    I use Q8 506.01 0W30 longlife very good oil no problem at all
  2. Re: 1.9 TDI PD 130 what oil???
    Jul 2009
    Belgium
    I use Q8 oil 506.01 0W30 longlife and i change it every 17.000KLM instead of 30.000KLM no problem at all specially in very cold winter
  3. Re: 1.9 TDI PD 130 what oil???
    Jan 2010
    France
    How do you determine whether your engine is on a fixed or longlife schedule, what's the difference?
  4. Re: 1.9 TDI PD 130 what oil???
    May 2006
    Redruth, United Kingdom
    How often is it serviced? fixed service is every 10,000 miles or once a year regardless, longlife can take up to 18 odd months and 20,000 miles.
    Guy
  5. Re: 1.9 TDI PD 130 what oil???
    1836 Post(s)
    Only by interrogating the instrument panel using a diagnostic computer can you tell for sure which schedule it is on. Whatever it is on, I strongly advise you to go to annual servicing but stick with the Longlife III spec oil if you wish.
  6. Re: 1.9 TDI PD 130 what oil???
    Nov 2006
    Manchester
    Just had the car serviced on the fixed term scheme from the ********. Not sure what oil was used. Dosen't say on the invoice, just something about 'LAVS'?! What's that?
    Thanks.
  7. Re: 1.9 TDI PD 130 what oil???
    #17
    Jan 2010
    France
    Not sure what LAVS means, could it possibly be the cost of disposing of the old oil in an environmentally friendly way?
  8. Re: 1.9 TDI PD 130 what oil???
    #18
    Jan 2010
    France
    Final question, I think...
    With the fixed oil change regime, I assume a service indicator light comes on after 10k/one year, or is this only applicable with the LongLife variable regime?
    I guess you can reset this manually.
    Also, is another way of telling whether your car is on a fixed or longlife regime by checking the countdown to next service indicator. If it reads over 10k, can you assume it's on longlife?
  9. Re: 1.9 TDI PD 130 what oil???
    #19
    May 2006
    Yes, fixed schedules will have a 10k and count down towards service (on some anyway). Not sure about the variable ones, no one here has one of them
  10. Re: 1.9 TDI PD 130 what oil???
    #20
    Nov 2006
    Manchester
    Quote Originally Posted by Magman View Post
    Turns out LAVS is Audi's longlife oil AVS! i.e. must be 5W-30.
    Someone here (can't find post), put a litre of 5W-40 instead of 5W-30 to top-up. I don't think it shoud be too much of a problem on the 10K/1year fixed term service as they get an oil change then.
    What's the difference between 5W-30 and 5W-40? Thinner? Thicker?
    How many litres does the oil tank hold? 3 litres?
  1. What oil should I use - 04 Passat 130 1.9 TDi
    By TeaTimeGilly in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-05-2016, 06:09 PM
  2. Audi covers new ground with 2010 q7 suv
    Last Post: 15-04-2009, 08:08 PM
  3. Answers From The Oil Expert
    By oilman in forum Archive posts
    Last Post: 05-10-2007, 03:25 PM
  4. Replies: 0
    Last Post: 20-07-2006, 09:08 PM
