Thread: Passat 1.8 No Power On Pull Off
  1. Passat 1.8 No Power On Pull Off
    Norfolk
    Hi, wondering if anyone could shed some light on my problem or give me some advice.
    I have a 1998 R Passat 1.8 20v (non Turbo)
    The issues I am facing are an intermitent problem but they are so frustrating and I cant seem to find what is causing it. I am finding that quite often I will go to pull away at either lights or a roundabout etc and I will go to give the car gas as I normally would and lift clutch pedal to pull away and there will just be virtualy no power. Almost like I am pulling away in 3rd or something. Once I realise its happening I have to put clutch in give more revs to get it to go. It seems more common on urban runs etc around town. When on a long high speed journey its quite nippy and sharp. I have tried using injector cleaner on it but dowesnt seem to make a difference. I also have a strange problem where at low revs when coming to a stop or if just idling along in traffic the engine will rev up and down on its own with no input from the accelerator. I can feel the pedal moving under my foot but im not the one causing it.
    Any help would be greatly appreciated.
    Matt
  2. Re: Passat 1.8 No Power On Pull Off
    Norfolk
    Faulty throttle position sensor ?? Get a code read
  3. Re: Passat 1.8 No Power On Pull Off
    Norfolk
    I assume that is done using one of the cables you attach to the car and a computer?
  4. Re: Passat 1.8 No Power On Pull Off
    Mar 2008
    Just Cumbria now.
    yes
    Nothing to see here, move along..
  5. Re: Passat 1.8 No Power On Pull Off
    london
    i was embrassed to say anybody in da begining that my pedal is feeling like moving withput my will ha ha ha
    i had the same problem my firend on a 99 golf
    throthle body problem i did not get it repeired
  6. Re: Passat 1.8 No Power On Pull Off
    Aug 2009
    United Kingdom
    Quote Originally Posted by tazmania_1981 View Post
  7. Re: Passat 1.8 No Power On Pull Off
    Norfolk
    So if its a throttle body problem, is that repairable is even broken or is it one of those things that just happens on this particular model of car?
    thanks
    Matt
  1. Replies: 21
    Last Post: 16-07-2015, 03:07 PM
  2. Important Power Loss / Turbo loss on VW Passat 1.9TDI
    By mubsy812001 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-06-2010, 03:14 PM
  3. Replies: 0
    Last Post: 15-01-2008, 09:05 PM
  4. Passat Loss of power (no not the maf ?)
    By JayZee in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-09-2007, 09:43 PM
  5. remap ptorque 02 passat 1.9tdi SMOKE NO POWER HELP!
    By ahsanx in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-07-2007, 04:32 PM
