Thread: ESP off light - codes - which parts?
Results 1 to 10 of 11
  1. ESP off light - codes - which parts?
    warrington, UK
    Hello
    My wife's car is a 55 plate 2.0 Golf Plus TDi. The ESP OFF light came on 2 days ago for no reason. Got my mechanic to run a diagnostic on it today and it came back with these codes:
    01435 Brake Pressure Sensor G201
    01309 PAS Control Module J500 - no comms
    Can anyone tell me exactly what parts I need to source and their part numbers please?
    I have read the other threads on ESP topic but I need specific part numbers.
    Also has anyone sourced parts for this problem from BBA Reman?
    Thanks for any help
  2. Re: ESP off light - codes - which parts?
    Canada
    1K0 614 517 AE BEF is the ABS/ESP controller you need. its the 201 sensor failure and there are no re-manufactures of this product.
    Rob
    VW Tiguan 4motion 2.0T 2015 - Awesome snow churning 4x4 GTI 😉
  3. Re: ESP off light - codes - which parts?
    1836 Post(s)
    This means a new ABS pump. BBA cannot yet remanufacture this part, I keep asking them about it but so far no luck.
  4. Re: ESP off light - codes - which parts?
    warrington, UK
    Thanks for your replies
    Is 1K0 614 517 AE BEF the part number for just the sensor or the whole ABS pump including the sensor?
    Is this the same part on later Golf Plus models or did VW sort the problem and upgrade the part? if they did upgrade can it just be transplanted across?
    Thanks again for your help
  5. Re: ESP off light - codes - which parts?
    Canada
    Its the whole pump, the sensor is inside the control unit and is not replaceable.
    This unit is used across the golf platform so you can move them around, but you may just end up with another failing I think AE is the updated part so may be worth hunting for one like that.
  6. Re: ESP off light - codes - which parts?
    warrington, UK
    I take it the part number above is for the AE version of the pump then?
    1K0 614 517 AE BEF
    Do you have any idea what year/model these were fitted to so that I can call some salvage yards?
    If not I can check with VW tomorrow
    Thanks for your help
  7. Re: ESP off light - codes - which parts?
    1836 Post(s)
    Quote Originally Posted by munchkincoupe View Post
    You and thousands of other people, you should see the prices these are fetching used, 75% of the new price!
  8. Re: ESP off light - codes - which parts?
    warrington, UK
    I've managed to track one down at a salvage yard for £90 delivered from a later model
    Fingers crossed it does the trick!?!
  9. Re: ESP off light - codes - which parts?
    1836 Post(s)
    What are the two unit’s part numbers?
  10. Re: ESP off light - codes - which parts?
    warrington, UK
    Crasher - parts arrived today and numbers are 1K0 614 517 H and 1K0 907 379 K - are these compatible parts with my car?
  1. ESP light will not come on
    By jmhaze in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-11-2009, 11:20 PM
  2. Please Help A3 Sportsback '09 DPF Warning Light!
    By Foggie in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-10-2009, 12:48 PM
  3. "How To" The FAQ & How To Thread
    By Ben in forum General
  4. engine judder / vibrations and esp light stays on
    By gusyah in forum Archive posts
    Last Post: 29-01-2008, 02:49 PM
  5. Is ESP standard on Y reg A3 1.8T Sport ?
    By AlexP in forum Audi A3 - Archive Topics
    Last Post: 10-06-2007, 02:01 AM
