Thread: Service intervals
  1. Service intervals
    Sep 2008
    Ludlow Shropshire
    Can anyone enlighten me on B8 1.8T petrol S Line servicing.
    My B6 was quite straightforward with a variable service around 17k, max 24 months.
    My new B8 has oil service max at 12 months with the variable inspection at 24 months. Clearly this could lead to the two occurring quite close together. Am I missing something?
    Thanks in advance.
    B5 A4 SE saloon (lava black) B6 A4 sport saloon 1.8T (silver) B8 160 S line, Now gone to a better place - well, the local Audi dealer. (silver)
    8J TT S-line Tdi 170 (phantom black) 8J TT Roadster TFSI, nav, my wifes new little baby. (phantom black)
    A6 S line 177 Tdi loaded with all the MY14 toys plus heated seats (phantom black)
  2. Re: Service intervals
    May 2007
    knee deep in clunge
    14 Post(s)
    From memory the new regime indicates the first service requires oil and filter and the additional service will be for your pollen filter,there are two service indicators one for oil and the second for additional items like pollen,plugs,air filter and brake fluid plus gearbox oil change for auto.
    So in most cases the oil service is due around 14,000 miles but the pollen is due at 19,000 or 24 months then most dealers are carrying out both to reduce the amount of visits but the as the first service may only require the oil change then the labour cost is greatly reduced as the fleet car market requested.
    This service plan causes great confusion as there are two service indicators so more complaints as the driver soon finds the second warning on the drivers display after the first service, due to the additional items schedule or the dealer has not reset both lights.
    I will post a more accurate description but that's roughly what to expect
    Maintenance concept
    At roll-out of the Audi A5/A4, an improved maintenance
    concept with reorganised maintenance work and
    times will be introduced to meet the various customer
    driving profiles.
    This maintenance concept will also be introduced
    on the Audi A3 and Audi TT from model year ‘08
    onwards.
    A key component of the improved maintenance
    concept is the distinction between "oil change" and
    "inspection", instead of coupling the service events
    to the oil change intervals as previously.
    Flexible event (oil change)
    Mileage based events
    Since time and mileage based service events are
    now indicated, process reliability is higher.
    This means that there is no danger of service events
    being missed without the customer receiving prior
    warning. The requirement for this is that the Service
    Interval Display is reset correctly.
    Time based events
    The Service Interval Display now indicates to the
    customer not only when the oil change is due, this
    being a flexible event, but also when time and
    mileage based service events are due.
    As usual, this is indicated to the customer via the
    dash panel insert.
    Additional information can be retrieved via the "Car"
    menu, the MMI or the radio display
  3. Re: Service intervals
    Nov 2008
    Suffolk
    Can you change to fixed servicing eg every 15k or similar?
    2018 Amarok V6
  4. Re: Service intervals
    Quote Originally Posted by jakerade View Post
    Hope so as I am paying on maintenance contract for an annual service as I dont like the variable. We have had variable on our A3 since new but it just does not sit well with me, oil change every two years.
    2015 Floret silver A3 Sportback 1.4 TFSI Sport 150 COD
    2005 Liquid Blue A3 Sportback 2 litre FSI SE
  5. Re: Service intervals
    Nov 2008
    Suffolk
    exactly my thought - they pick the car up and leave me a courtesy car so i dont mind if its every 10k to be honest.
    I just want to make sure i dont miss a service at the end of the maint contract
    2018 Amarok V6
  6. Re: Service intervals
    May 2007
    knee deep in clunge
    14 Post(s)
    You have the option for long life or time and distance
    Time and distance will be 12 months 9,000 miles from memory
  1. XP - Very Slow on Start up...
    By RickT in forum Home Tech Shed
    Last Post: 16-08-2010, 05:56 PM
  2. Please Help Car switched from Long Life to Time / Distance service by accident?!?
    By wookiee in forum Golf MK5 - 2004 - 2009
    Last Post: 18-07-2010, 11:25 PM
  3. v6 tdi service intervals
    By Gcooper in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-02-2008, 11:47 AM
  4. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
