Thread: Stabiliser bar bushes and brake pipes
  1. Stabiliser bar bushes and brake pipes
    France
    Just had my A6 2.7T in for it's CT (French MoT), they've told me my front brake pipes are showing signs of corrosion and the bushes on the front stabiliser bar are worn and need replacing (these aren't failures here - just suggestions ).
    Big job or not? I'd rather tackle it before relying on a local garage. Cheers for any advice
  2. Re: Stabiliser bar bushes and brake pipes
    Pembrokeshire
    22 Post(s)
    if its the solid metal brake pipes, you need to remove them and get new ones made up by someone with a suitable flaring tool, using cuprinol pipe. dont use the cheaper plain copper pipe. then bend them to shape, tighten up and bleed, probably using vagcom.
  1. Wishbone Front / Rear Axle Bush which brand
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 12:27 AM
  2. Golf MKIV Rear Axle Bushes
    By Stanhope in forum Golf MK4 - 1999 - 2004
    Last Post: 09-09-2008, 08:08 AM
  3. Rear Axle mounting / Pivot bushes > Has anyone replaced? Easy? Hard? Tips?
    By Steve Foster in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-02-2008, 01:52 PM
  4. mot
    By graham toogood in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-10-2007, 06:20 PM
  5. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
