Thread: lumpy uneven tickover slight loss of power over 3000 rpm mk5 golf gt tdi 140
Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
  1. Re: lumpy uneven tickover slight loss of power over 3000 rpm mk5 golf gt tdi 140
    #21
    Aug 2011
    Meath
    Crasher is Steve Cresswell one of the top VAG men in the UK. He gives free advice on here a nice fella with a fuse shorter than a really short fuse. He helped me on his way out to a party on New years Eve try that with commons road cars! Is what pricey? This is a good site for advice, a good rant and craic. There are a couple of Irish VAG sites but I don't find them helpful
  2. Re: lumpy uneven tickover slight loss of power over 3000 rpm mk5 golf gt tdi 140
    #22
    Aug 2011
    Meath
    If you're stuck give me a shout
    Quote Originally Posted by 8loopy8 View Post
    hhaha ill keep an eye out for the sacastic crasher you know if there pricy ?
  3. Re: lumpy uneven tickover slight loss of power over 3000 rpm mk5 golf gt tdi 140
    #23
    Sep 2013
    dublin ireland
    cheers man good site lots of ppl online to give info i dont feel alone in my piece of ***** problems anymore hahaha got bit mixed up tought i had to replace the whole housing thats why was asking if was pricy..... i get now tho ha that its only just the paper filter great diagram here TDISport - The Diesel Forum and Community • View topic - Mk5 Golf TDI Fuel Filter Replacement from diff site ill be givin that a whack tomorow save meself a mechanic bill *****
    u know anytin about the tandem pump as in how would i know if oil was mixin with the diesel? had to top up oil tonight oil light low came on trew a litre of mobile 40w50 in see how it gose i supose
    also would u recomend changing maf senser if car was only gettin a gud turbo btween 2000rpm and 3100 rpm?
  4. Re: lumpy uneven tickover slight loss of power over 3000 rpm mk5 golf gt tdi 140
    #24
    Aug 2011
    Meath
    You need a diagnostic scan, if the tandem pump is banjaxed uou have to replace it, oil/diesel is BAD MF
  5. Re: lumpy uneven tickover slight loss of power over 3000 rpm mk5 golf gt tdi 140
    #25
    Sep 2013
    dublin ireland
    had it hooked up to computer so prob woulda showed up can rule that out so dmf was anthor brought up by one mecanic but 1 out of 4 said that others said engine should be making knocking noise from clutch and the shake would also be resolved by pushing down on clutch pedel and there would be like a step on the clutch when changing gear was quted mad prices thank *** didnt do it at 1000 to 1200 from independent garages anyways im off man cheers forr the info il swap over filters tomorow see how i get on nice1 for the info
  6. Re: lumpy uneven tickover slight loss of power over 3000 rpm mk5 golf gt tdi 140
    #26
    gwent
    hi with my idle problem the issues came back but not loss of power.The next thing i was going to change was the wiring loom on top of the injectors however when the car went to the garage he just checked one more thing and found that the timing was out by 1 tooth (his terms)once this was corrected the car was transformed and the lumpy and shaking on tick over is gone!! To think i put up with this for so long and it was caused by the timing belt change when i 1st BOUGHT the car.I hope you get yours sorted because i know how flustrating this is.
  7. Re: lumpy uneven tickover slight loss of power over 3000 rpm mk5 golf gt tdi 140
    #27
    Sep 2013
    dublin ireland
    interesting ...... the thing with mine was the timing belt was changed last week .. but the problem exsisted before change..
    you think this could be over looked by a mecanic ? as in just replacing one for the other with markers? good theroy gona ask mecanic to check it over was it just a matter of looking or did the belt have to be removed .. do you rember how much it cost my wallets low at the moment after buying the golf
    cheers 4 input
  8. Re: lumpy uneven tickover slight loss of power over 3000 rpm mk5 golf gt tdi 140
    #28
    Aug 2011
    Meath
    I have seen plenty of belts changed according to the last guy that changed it's tipex marks. I use the makers marks it seems to work fine. Set the fltwheel on TDC and take off the timing belt top cover, if you see fresh tipex or paint marks get the timing checked.
  9. Re: lumpy uneven tickover slight loss of power over 3000 rpm mk5 golf gt tdi 140
    #29
    Sep 2013
    glasgow
    i agree tippex marks are bad could give timing errors
  10. Re: lumpy uneven tickover slight loss of power over 3000 rpm mk5 golf gt tdi 140
    #30
    Sep 2013
    dublin ireland
    after 2 months finally got round to timing belt today
    had to strip the belt down twice as the bottom crank could eitheir be set to the left or right im no mecanic i was just holding the torch haha learned alot about timing belts today tho but have to agree anyone getting there belt done ask to be set to tdc
    the good news is yesssssss the dirthy fukwad of a shake has left the golf like a new car mpg seems on the up aswell and alot smoother was only out by one tooth amazing used the locking pins to get tdc and crank lock
  1. Please Help Best Golf for £10k and confusion over different engines?
    By deshg in forum Golf MK5 - 2004 - 2009
    Last Post: 21-09-2010, 07:47 PM
  2. Golf 1.6 tdi 105 PS quick question about power level
    By Alabama978 in forum Golf MK6 - 2009 - 2013
    Last Post: 30-12-2009, 07:26 PM
  3. The fastest-accelerating volkswagen yet: The new golf r
    Last Post: 15-09-2009, 08:29 PM
  4. Audi covers new ground with 2010 q7 suv
    Last Post: 15-04-2009, 08:08 PM
  5. Loss of Power Golf TDi Mk3
    By pritesh in forum Golf MK3 - 1993 - 1999
    Last Post: 30-09-2007, 04:12 PM
