Thread: 1.9tdi GL Estate (1z) 1995 Vacuum Help
  1. Question 1.9tdi GL Estate (1z) 1995 Vacuum Help
    Hiya's,
    I am slowly losing the will to live
    Got a decent passat 1.9tdi GL estate with the 1z engine in
    I have sorted minor repairs/fixes, she idles fine and no smoke whether idling or with foot down (but read below)
    Now i have all my silicon tubing to redo all the engine bay rubber tubing/piping
    Problem is this ....................
    I have joined different vw/audi etc foums in search of a definitive vacuum pipe layout for my engine
    I have been searching for over a week approx 3hrs a night lol (hence losing will to live !) and only found other (mainly us/canada spec'ed engine layout/pipe pics etc)
    Can someone point me to a comprehensive pic/schematic of the 1.9 tdi 1z pipework layout
    I have replacing vacuum pipe inside the ecu and put ecu back and then from ecu i just replaced my 1st piece of rubber tubing that goes from ecu to nipple just after the maf (ait flow meter i usually call em or afm for short)
    Reason i desperately need diagram/schem/pics/drawing is the turbo seems to die in 4th and 5th gear when trying to overtake or go up a gradiant
    Also i found what i assume is a pipe missing from the air filter box to what i think is the N18 (think its N18, it's down by maf just upstream from air filter) (ohh i assume near the ecu on the firewall that's the N75 ?)
    Well i put a piece of new tube from air filter box to what i think is the N18 (only thing that had a unused nipple on it)
    Just don't want to start cutting new silicon up if the tubing i'm replacing has been messed around and i end up having too short a piece for certain parts
    Sorry to waffle on but i'm quickly losing my mind searching and posting and not getting anywhere lol
    Any input would be great
    Many Thanks
    Def
  2. Re: 1.9tdi GL Estate (1z) 1995 Vacuum Help
    All sorted (i think)
    I knew something wasn't right with the vacuum layout when i looked earlier
    Seems someone before me had swapped 2 tubes around, mainly the ecu to inlet mainfold (intake pressured) and the Atmospheric pressure (filtered air) to the N75
    Took her for a quick run
    Besides a few initial slight hesitations she's running fine
    Def
  1. Important Power Loss / Turbo loss on VW Passat 1.9TDI
    By mubsy812001 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-06-2010, 03:14 PM
  2. Smarter, safer, greener: New golf estate unveiled
    Last Post: 13-06-2009, 04:19 PM
  3. Smarter, safer, greener: New golf estate unveiled
    Last Post: 25-05-2009, 04:19 PM
  4. audi 80 1.9tdi estate handbrake
    By eddiemax28 in forum 80 - 90
    Last Post: 12-03-2008, 02:29 AM
  5. New Škoda Fabia Estate Uk Pricing And Spec Is Announced
    Last Post: 03-12-2007, 08:08 PM
