Thread: "Luggage comp Open" fault
  1. "Luggage comp Open" fault
    Jun 2008
    2003 Mk4 GTTDi, dash says "luggage comp open" even when shut and the alarm goes off randomly at night when locked.
    I found out there is a common problem with the rear washers blocking, this then pops the pipe off when used and the washer fluid leaks onto the latch causing the fault. So I checked this and sure enough the pipe was off. New latch ordered and fitted. BRILL I thought!
    It lasted 3 days then the fault returned, now when the boot is shut it turns out the boot light but still says "luggage comp open" on dash. I even swapped the latch with a friends on the off chance it was faulty and it's the same .
    I have also noticed that when I'm sat in the car with it running when I press the brake the light goes out and when I release it it comes back.
    does the system run through the brake switch? or is it more likely a comfort control mod fault?
    I've used my VCDS and there are no fault codes present. Hope someone can help???
  2. Re: "Luggage comp Open" fault
    nottinghamshire
    i think its a common fault and starts from the rear wash pipe, i think water is your problem, strip down the boot again clean it out and dry it up plently of wd40 and check the wiring is in tact
  1. Audi a8 2003 Current gearshift program problem
    By eints77 in forum VCDS - Help Requests
    Last Post: 20-07-2010, 02:58 PM
  2. low engine power from cold
    By saabsalltheway! in forum VCDS - General Questions
    Last Post: 30-11-2009, 10:21 PM
  3. Healp needed VAG com
    By Snooze1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-06-2009, 07:47 AM
  4. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
  5. Check my scan
    By kite in forum VCDS - General Questions
    Last Post: 11-05-2009, 08:03 PM
