Thread: Code Fault Recognition
  1. Code Fault Recognition
    May 2008
    Can any confirm to me what these codes are faults for, i have a good idea however if anyone knows more than me any and all info is appreciated.
    First one
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Control Module Part Number: 03G 906 016 G HW: 028 101 136 4
    Component and/or Version: R4 2,0L EDC G000SG 5705
    Software Coding: 0000072
    Work Shop Code: WSC 06435 000 00000
    1 Fault Found:
    16618 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
    P0234 - 000 - - - Intermittent
    Freeze Frame:
    RPM: 2520 /min
    Torque: 204.0 Nm
    Speed: 132.0 km/h
    Load: 43.9 %
    Voltage: 14.44 V
    Bin. Bits: 00101000
    Absolute Pres.: 1917.6 mbar
    Absolute Pres.: 2448.0 mbar
    Readiness: 1 1 0 0 0
    I take it this means my Turbo needs either replacing, or doing something to it.
    What id like to know is..
    What exactly is the problem?
    How much will it cost?
    Next one, i aint got a clue what this is..
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 B HW: 1K0 907 951
    Component: Gateway H08 0090
    Revision: 08 Serial number: 24001039176E5C
    Coding: 3D0F0F42070101
    Shop #: WSC 06435 000 00000
    1 Fault Found:
    00470 - Combination comfort Databus in Single Wire
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 254
    Reset counter: 57
    Mileage: 101771 km
    Time Indication: 0
    yeah so any help is greatly appreciated.
  2. Re: Code Fault Recognition
    16618 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition,does not necessarily,mean you have a faulty turbo,check all vacuum hoses,check the solenoid valve for boost pressure control,and check manifold pressure sensor.
    Means there is a break in one of the can-bus wires in the comfort system,a bit of a problem to find as it could be any where,but no real problem,before the other one breaks,as the system is fully functional with one wire.
  3. Re: Code Fault Recognition
    Sep 2009
    manchester, england
    boost pressure fault i had exactly same fault and explination on mine i would try replacing boost pressure sensor first bout 20 quid nothing compared to a a3 turbo
  4. Re: Code Fault Recognition
    May 2008
    nice one, if that is the problem that would be a massive bonus.
  5. Re: Code Fault Recognition
    Jun 2009
    Bedfordshire
    Jay2.0 tdi, how was the car reacting before you got this fault code?
  1. Audi a8 2003 Current gearshift program problem
    By eints77 in forum VCDS - Help Requests
    Last Post: 20-07-2010, 02:58 PM
  2. low engine power from cold
    By saabsalltheway! in forum VCDS - General Questions
    Last Post: 30-11-2009, 10:21 PM
  3. gearbox isolator switch??????
    By a25c in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-11-2009, 11:29 PM
  4. tiptronic g/box fault code
    By goonersteve24 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-04-2009, 01:15 PM
  5. Please Help Climatronic Fault Code.
    By gbdxo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-04-2009, 04:49 PM
