Thread: C5 V6 TDI Fault Codes
Results 1 to 10 of 12
  1. C5 V6 TDI Fault Codes
    Dec 2007
    I have recevied the following codes:
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-10 - - - Intermittent
    00522 - Engine Coolant Temperature Sensor (G62)
    30-10 - Open or Short to B+ - Intermittent
    01318 - Control Module for Injection Pump (J399)
    49-00 - No Communications
    01268 - Quantity Adjuster (N146)
    37-00 - Faulty
    01266 - Glow Plug Relay (J52)
    31-10 - Open or Short to Ground - Intermittent
    00532 - Supply Voltage B+
    05-00 - Input Open
    Any ideas if any of these will stop the engine running?
    I couldnt access the immobiliser - not sure why. The engine doesnt sound like its getting fuel?
    Any help welcomed.
  2. Re: C5 V6 TDI Fault Codes
    Feb 2007
    The first code you list sounds as though it could stop the engine from starting.
    What are your symptoms??
    '12 Audi A4 Allroad 2.0 TDI 'CGLC'
    '11 VW GOLF BLUEMOTION 1.6 TDI. 'CAYC'
    '07 VW T5 TRANSPORTER T32 ,,,,,, 'BNZ'
    '91 VW GOLF SPORTLINE CABRIOLET 1.8 GTI. 'DX'
  3. Re: C5 V6 TDI Fault Codes
    Southern County Softy
    17 Post(s)
    I would save, then clear the faults and see what comes back.
    Is the car not starting, fuel pump module fault look ominious !!
    A4 2.5 tdi QS (mapped)
  4. Re: C5 V6 TDI Fault Codes
    Dec 2007
    The engine seems to me lik it isnt getting fuel. It will try with easi start but just turns over. Have tested the lift pump which works out. I think its not getting any fuel. I could get access to the immobilsor via VAG COM.
  5. Re: C5 V6 TDI Fault Codes
    Dec 2007
    I did as you said - hence the list of codes I pasted in. When I re ran the software I didnt receive any fault codes.
  6. Re: C5 V6 TDI Fault Codes
    17 Post(s)
    Try cracking a injector pipe and see if fuel is getting to them.
  7. Re: C5 V6 TDI Fault Codes
    Dec 2007
    Anyone have any experience of these guys - http://www.dieselpumprepairs.com/#/b...mps/4533360090
  8. Re: C5 V6 TDI Fault Codes
    17 Post(s)
    Have a search on the web for Diesel Bob
  9. Re: C5 V6 TDI Fault Codes
    Dec 2007
    I saw them as well - reconditioned pump from 500 depending on what they find. I am still waiting to hear back from the other guys. Will kepp you posted.
  10. Re: C5 V6 TDI Fault Codes
    Jan 2009
    Falmouth, UK
    Diesel bob just did mine, fine job. recommended.
    2001 Audi A6 2.5TDI Avant quattro Sport, Celtic Tuning remap, TurboDynamics MD438 hybrid turbo, 3" decatted Longlife stainless exhaust, Bosio Race683 nozzles
    2004 Audi A4 1.9TDI Avant quattro + Superchip
    1988 Yamaha FJ1200
  1. alarm fault codes
    By A6TYY in forum VCDS - Help Requests
    Last Post: 17-08-2009, 08:01 PM
  2. Trim Confusion
    By ocelot0411 in forum Golf MK5 - 2004 - 2009
    Last Post: 15-08-2009, 11:16 AM
  3. 2001 Passat TDi 130 Engine running fault nightmare
    By Passatnightmare in forum Chat - Anything with wheels
    Last Post: 05-08-2008, 08:48 PM
  4. VW T4 2.5 Tdi Engine fault codes P1556 and P1162
    By j13oly in forum Archive posts
    Last Post: 03-02-2008, 08:10 PM
  5. Audi takes pole position in TDI diesel development
    Last Post: 01-04-2006, 07:34 PM
