Thread: erratic indicators & hazards - is haz switch the culprit ?
  1. Question erratic indicators & hazards - haz switch WAS the culprit !!
    Indicators on 2001 TDi130 are erratic - sometimes work ok - sometimes will blink once or twice then stop - sometime wont work at all. Pressing hazard switch has same erratic results. Passenger footwell dry. Indicators blink as normal when locking or un-locking. Suspect relay problem.
    Some other posts suggest that the relay is part of the haz switch and that haz switch may be the culprit.
    - do my symptoms point to this ? can somebody confirm that relay is part of haz switch?
    Trevor
  2. Re: erratic indicators & hazards - is haz switch the culprit ?
    Dec 2008
    Hi Trev,
    Had the same problem with mine last year was indeed the hazzard light switch.Got one from euro car parts for about £1o i think.Hope this has helped.
    Neil
  3. Re: erratic indicators & hazards - is haz switch the culprit ?
    Yep - it was the hazard switch. I got mine from GSF about £14, however faceplate about 2-3 mm wider than original fit and therefore jammed "on" in recess!! Fortunately able to swap faceplate with original.
    Trevor
  1. Question Fog lights install
    By deadly4u2nv in forum Golf MK5 - 2004 - 2009
    Last Post: 26-11-2014, 12:59 PM
  2. Indicators not working but hazards do !!!!
    By bigtroot in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-08-2009, 10:22 AM
  3. Wonky indicators
    By jonjosar in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 31-07-2009, 10:12 PM
  4. Foglights Retrofit - VW Jetta / Golf
    By RickT in forum Volkswagen
    Last Post: 27-06-2009, 06:06 PM
  5. Golf Mk 3 indicators / Hazard switch problem
    By rtully in forum Golf MK3 - 1993 - 1999
    Last Post: 09-11-2007, 03:13 PM
