Thread: Fabia immobiliser problems
Results 1 to 10 of 13
  1. Fabia immobiliser problems
    Hi my 2000 Fabia Classic is currently lurking in tesco's car park as the car refuses to run, the immobiliser symbol on display is flashing and the car just starts and stops again, this has happened once or twice before, but I have always managed to get it to start eventually. Does anyone know how to get it going again? Do I need a new key?
    Ps I do not have the key fob thing mentioned in the handbook
    any help would be appreciated
    Kate
  2. Re: Fabia immobiliser problems
    AA got it going and have got it home now, but still same problem, any advice?
  3. Re: Fabia immobiliser problems
    Hello.
    Sounds like the code in the key is not being read or recognised by the ECU which results in the immobiliser 'staying on'. A fault code should be stored which will help with the diagnosis.
  4. Re: Fabia immobiliser problems
    Mansfield, UK
    It could be the reader coil, the wiring to it, or the instrument cluster itself. Unfortunately it will be very difficult to track down without changing parts for elimination purposes.
  5. Re: Fabia immobiliser problems
    Yes, or it could even be the ignition key......
    I would try the diagnostic route myself, might work out cheaper in the long run.
  6. Re: Fabia immobiliser problems
    Mansfield, UK
    Yes but the diagnostics will come up with the same code regardless of what the problem actually is.
    01176 - Key
    07-10 - Signal too Low - Intermittent
  7. Re: Fabia immobiliser problems
    can anyone tell me where you plug the diagnostic thing in on the fabia mark 1?
  8. Re: Fabia immobiliser problems
    Mansfield, UK
    It's behind the cubby hole near the driver's knee. Pull it fully open and then pull it again to reveal the OBD socket.
  9. Re: Fabia immobiliser problems
    Thanks,
    not very successful,
    Engine 17664, 17975 both not in book
    A/T- linking error
    SRS- no codes
    ABS - linking error
    trouble is it seems to be working now too, so not sure if I can trust it
  10. Re: Fabia immobiliser problems
    It is now doing exactly the same thing
    I got in it yesterday, wouldnt stay started with both keys, and immobiliser symbol on dash flashing. I tried it 1 hour later and it started ok
    Help advice wanted please
  1. Immobiliser Problems i think, Please Help
    By Lofty79 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-07-2011, 12:18 PM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. Immobiliser problems
    By marcus36 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-04-2008, 08:51 PM
  4. New Škoda Fabia Estate Uk Pricing And Spec Is Announced
    Last Post: 03-12-2007, 08:08 PM
  5. Škoda Fabia Gets Sporty
    Last Post: 01-12-2007, 06:59 PM
