Thread: clutch judder
  1. clutch judder
    Hi all
    has anyone else experianced a bad judder/ shudder when pulling of the mark usually when the engine is cold ie first 5min of driving, does it with traction on and off so not that. car fine when warm, 2.0 tdi gt sport 08 18k
    thanks
  2. Re: clutch judder
    uk
    I sometimes get juddering when pulling away when the engine is cold, the same, first 5 - 10 minutes. Doe not happen when reversing off the drive, only when pulling away.
    1.6 FSI Match, 57 plate.
  3. Re: clutch judder
    Oct 2009
    Gloucestershire
    Snap! only when it's damp though, then it's fine after the first couple of pull aways in first and the rest of the day. I was wondering if a cold start and turning everything on to get going is causing the revs to drop, thus causing the initial judder on clutch take up. I have found a bit more use of the accelerator helps.
    57 plate GT Sport TDi 140.
  4. Re: clutch judder
    Its been back to garage a few times now, they have changed the flywheel and clutch, checked all the timing tosion valves etc. and everything seems perfect!!!!!! In the garage today for service and also checking the clutch switch on the request of vw technical so we shall see. I think it maybe down to the throttle pedal unit itself may need senting up again as it needs a good inch of movement for any power and any light touch causes stutter feeling
  5. Re: clutch judder
    Mar 2009
    staffs
    im sure golfs had this problem a few years back with damp getting on the clutch plate im sure vw are aware of this problem, have a look on the forum or google it
  6. Re: clutch judder
    Sep 2008
    Nottingham
    I get this too on my 08 with 19k, its been in on numerous occassions. But surprise surprise they cannot fault it.
    That or the lumpy idle... would you guys say both issues point to DMF/Clutch?
  7. Re: clutch judder
    went into the garage again and they have checked everything pretty much now so just one of those things really with the car so in other words tough live with it!!!! vw wash their hands of it basiclly
  1. Clutch change at Audi and now Judder, please help! :(
    By Melissa in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-11-2010, 01:20 PM
  2. Clutch Pedal Judder
    By macker6464 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-03-2009, 10:45 PM
  3. Caravelle clutch judder
    By williamstubbs@h in forum Touran - Sharan - Caravelle
    Last Post: 26-10-2008, 04:47 PM
  4. Clutch judder when cold
    By ukwigginle in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-04-2008, 05:48 PM
  5. Shafted....really?
    By Martin Burnard in forum Chat - Anything with wheels
    Last Post: 04-02-2008, 09:44 PM
