Thread: Mk6 Golf - VAG Com Tricks
Page 1 of 9 123 ... LastLast
Results 1 to 10 of 85
  1. Mk6 Golf - VAG Com Tricks
    Just been reading this thread in the Audi section;
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=69276
    Is there anything similiar for the mk6? I'm sure turning off the seatbelts will be do-able. What about the rev counter/speedo sweep?
    DaveB
  2. Re: VAG Com Tricks...
    Look, some clever chap has found out how to activate the Tyre Pressure Monitor System;
    To activate this option on your car is necessary to use VCSD to modify:
    [03 - ABS Brakes]
    [Security Access - 16]
    [Coding - 07] -> Long Coding Helper -> Byte 1
    Bit 3 - Tire Pressure Monitoring (PR-7K6) active (1 = active)
    [56 - Radio]
    [Coding - 07] -> Long Coding Helper -> Byte 8
    Bit 6 - TPMS Settings active
    [17 - Instruments]
    [Coding - 07] -> Long Coding Helper -> Byte 4
    Bit 0 - Tire Pressure Monitoring (TPMS) installed (1 = active)
    Anyone with a mk6 gonna try it?
    DaveB
  3. Re: VAG Com Tricks...
    BUT you can not activate something that is not fitted to the vehicle
  4. Re: VAG Com Tricks...
    I was under the impression that the tyre pressure monitoring systems used the ABS sensors; where the ABS detects that a wheel is turning less/more times than the others it assumes a difference in psi, and therefore flashes the warning?
    DaveB
  5. Re: VAG Com Tricks...
    Oct 2005
    Thread stuck and title changed
  6. Re: Mk6 Golf - VAG Com Tricks
    Manchester
    But why would you wanna discable a safety device?? Especially one as critical as this ??
    Mk6 Golf 2009 Deep Black Pearl 2.0 GTTDI 140, Vancouvers
  7. Re: Mk6 Golf - VAG Com Tricks
    Jun 2009
    Arundel West Sussex
    Good idea to make this a sticky thread.
    If someone with the software is willing to try and see what possibilities there are, I'd really like to know if the number of flashes with the lane change indicator 'nudge' can be increased to four or five as I find three not enough.
    Cheers,
    Dunc.
  8. Re: Mk6 Golf - VAG Com Tricks
    South London. UK
    Quote Originally Posted by dieselduncmk6 View Post
    Cheers,
    Dunc.
    I think that 5 flashes would be ideal for myself. 3 flashes is patently insufficient.
    2016 VW Golf MK7 Match Edition 1.4TSI 125ps 5dr in Reflex Silver.
  9. Re: Mk6 Golf - VAG Com Tricks
    Jul 2009
    Glasgow
    3 is more than enough for me after nearly being in a collision because of it this morning.
    Driving along a 2 laned road on the outside and used the comfort indicator to come into the inside lane. A car that was just ahead of me waiting to come on to the road I was on, obviously thought I was indicating to turn into the road he was sitting in (albeit I was a good distance away). He started to come out and then realised my indicator had stopped and just gave me a growl as I passed him.
    5 flashes and he would definitely have come out!!
  10. Re: Mk6 Golf - VAG Com Tricks
    Quote Originally Posted by paul.mgrath View Post
    Are you serious? It's not disabling a safety device, it's disabling a stupid little light and beep that reminds you you're not wearing your seat belt.
    Christ, what happens when you get into an old car and there are no buzzers or lights?
    DaveB
  1. What bugs you about the Golf Mk VI
    By james_tiger_woo in forum Golf MK6 - 2009 - 2013
    Last Post: 22-11-2011, 10:08 PM
  2. The scirocco r and golf r now available to order
    Last Post: 03-11-2009, 09:09 PM
  3. The scirocco r and golf r now available to order
    Last Post: 31-10-2009, 09:03 PM
  4. Golf And Eos Are Honoured Once Again At What Car? Award
    Last Post: 19-01-2008, 03:32 PM
  5. Replies: 0
    Last Post: 27-05-2007, 07:38 PM
