Thread: upgrading to D.I.S
Results 1 to 9 of 9
  1. upgrading to D.I.S
    Redhill, Surrey
    Hi all,
    i have just bought a 06 A3 sportback 2L TDI. and was wondering if its possible to have the D.I.S installed on it if so does anyone have an idea how much its likely to cost...or if its possible altogether.
    any help or comment will be appreciated
    many thanks
  2. Re: upgrading to D.I.S
    Dec 2007
    London/Surrey
    to be honest i doubt it would be possible. Then again in the motor world anything is possible but its looking to cost you an arm and a leg.
    You would most certainly need to fit a new dash board (clocks, speedo, rev.) If you could do it, then it wont be the new colour version. Speak to an audi dealer...they will more than likely say no there.
    COMING SOON: '14 A5 Cabriolet S-line Special edition, Daytona Grey
    CURRENT: 11' A5 S-Line Black Edition Ibis White
    previous: 09' A3 S-line Ibis White
  3. Re: upgrading to D.I.S
    May 2008
    Depends which clocks are installed on your car now, if you have the large red display then its possible, if not then you need new clocks.
  4. Re: upgrading to D.I.S
    Mansfield, UK
    I do quite a lot of these. New clocks required but second hand ones are no problem to code in. New steering wheel control module and associated stalk.
    Definitely possible and not that expensive using second hand clocks.
  5. Re: upgrading to D.I.S
    Redhill, Surrey
    hi thanks for the replys guys, going to go down to an audi dealer in next couple days see what they say. i think i have the right clocks just might need the relevant re-coding and stalks, will keep you updated.
    thanks again.
  6. Re: upgrading to D.I.S
    Mansfield, UK
    Which cluster do you have now? Could you post a picture?
    Good luck with your dealer.. the standard response is "Not Possible" to most things I base my business on!!
  7. Re: upgrading to D.I.S
    Dec 2007
    London/Surrey
    yep! thats the response i generally get. But its a different story when you order a new car and the factory forget to add something!
  8. Re: upgrading to D.I.S
    Redhill, Surrey
    will get a picture soon, the cluster i have has got the two main speedo + tacho clocks with time,temp, and mileage etc. then i have a display in the middle (where i guess the D.I.S would go) but instead i just have warning symbols for different things.
  9. Re: upgrading to D.I.S
    Mansfield, UK
    If you have warning symbols where the screen should be then your instrument cluster would need to be replaced with one that has a screen. It's not a big thing, as I said I can code second hand clusters in rather than paying £600+ for new ones!
  1. Upgrading A4 tdi 110 turbo/ mods/ tuning - Advice please
    By simyboye in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-10-2013, 07:26 PM
  2. Upgrading the existing factory fit alarm
    By aussie_surfer74 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-07-2009, 11:46 PM
  3. mk4 golf speaker upgrading
    By jonnny_27 in forum In Car Entertainment
    Last Post: 05-07-2009, 06:38 PM
  4. Upgrading STD Headlights
    By billythetidd in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-04-2009, 04:12 PM
  5. I'm considering upgrading the headlights
    By hagis in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-02-2008, 10:01 PM
