Thread: RE: Battery Problem, someone help please
Results 1 to 10 of 11
  1. RE: Battery Problem, someone help please
    Feb 2009
    Hi there, i'm new to this forum, own a audi a4 1.9tdi sport, my cars battery tends to die over night, ive had the alternator checked, changed the battery and the problem still occurs, had a diagnosis, which showed several problems, i am told the main problem to worry about is:
    00532 - supply voltage B+
    002 - Lower Limit Exceeded - Intermittent
    what could that be? and what do i do? someone help please!
  2. Re: Battery Problem, someone help please
    Southern County Softy
    20 Post(s)
    Taken from the rosstech wiki
    00532 - Supply Voltage B+: Signal too Low
    Possible Causes
    Wiring/Connectors from/to Control Module faulty
    Power Supply (Battery/Generator) faulty
    Possible Solutions
    Check/Repair Wiring/Connectors from/to Control Module
    Check Power Supply (Battery/Generator)
    Special Notes
    When found in an individual control module, it's most likely a local source (e.g. wiring/connectors).
    When found in multiple control modules at the same time, it's most likely a common source (e.g. ground spot, battery, generator).
    Intermittent codes are often stored during low outside temperature when the battery capacity goes down and may be ignored.
    Common with 16946/P0562/001378 - System Voltage: Too Low stored in other control modules.
    I would get the electics checked to see what is draining the battery
    A4 2.5 tdi QS (mapped)
  3. Re: Battery Problem, someone help please
    20 Post(s)
    Also as you have changed the battery that could be an old fault, have it cleared and see if it comes backafter a couple of days.
  4. Re: Battery Problem, someone help please
    Pembrokeshire
    22 Post(s)
    what you need to do is to find a mechanic that has a clue. something is draining the battery and this wont usually show up on diagnostics. with the car all switched off, bonnet up but bonnet switch closed, or battery on remote wires and bonnet closed, an amp draw test needs to be performed, then the faulty component isolated. removing fuses is a good start. it could be as simple as a boot light staying on, or and ecu not turning off.
  5. Re: Battery Problem, someone help please
    What is the charging rate of the alternator,measured over the battery terminals?
  6. Re: Battery Problem, someone help please
    Pembrokeshire
    22 Post(s)
    damn thats a lot of answers really quickly.
  7. Re: Battery Problem, someone help please
    20 Post(s)
    We all try to please (and increase our post count)
  8. Re: Battery Problem, someone help please
    May 2007
    knee deep in clunge
    14 Post(s)
    Quote Originally Posted by soh1b View Post
    Post all fault codes and especially check address 46
    Make sure all you consumers work for example check the led light in the drivers door lock.
    When you lock the vehicle it should flash quickly for 30 seconds or so then slow down.
    Make sure the everything turns off when removing the key and note the convience circuit may well stay active for 20 minuets as well as the engine ecu which stays powered up for about 10 mins.
    If you under take a closed circuit current draw allow at least 2 hours before taking a average current reading and your looking for 0.030 amps ideally.
  9. Re: Battery Problem, someone help please
    Feb 2009
    Thanks for the advice guys didn't expect so many replies, highly appreciated, i will have an attempt at everythings thats been said and let you know how it went!
  10. Re: Battery Problem, someone help please
    Oct 2009
    Wiltshire England
    The battery you fitted was it the correct spec for you car? Do you have an aftermarket alarm system that could be slowley draining your battery?
    Do you just drive on short distances not giving the battery a chance to charge fully?
  1. The Audi e-tron
    Last Post: 02-10-2009, 07:30 AM
  2. The Audi e-tron
    Last Post: 15-09-2009, 08:34 PM
  3. VW Golf Mk4 1.6 6v - Oil pressure problems/Random battery cut
    By paresh0407 in forum Golf MK4 - 1999 - 2004
    Last Post: 11-06-2009, 10:53 PM
  4. overheating problem 98 1.8 20v
    By victhepick in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-05-2008, 10:39 AM
  5. Battery drains overnight
    By Jonse123 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-01-2008, 01:53 PM
