Thread: Single beam Xenon or Bi beam for A4 (B6)
  1. Single beam Xenon or Bi beam for A4 (B6)
    Feb 2009
    Hi everyone,
    I am looking to upgrade my 2002 Audi A4 B6 headlights to HID xenon. However I do not want to order the wrong ones so can anyone tell me if I am after the single beam or bi-xenon. I do not know the difference and the headlamps on my car are standard projectors. Also is the fitment H7? I am also after 6000k or 7000k or can any recommend the best temp range ( I like the look of range rover sports xenon but do not know what K range they are)
    Thanks in advance
  2. Re: Single beam Xenon or Bi beam for A4 (B6)
    May 2008
    Finland
    A search would have found you the answer to this.
    1.) Fitment is H7 for both dipped and main beams
    2.) if by bi-xenon you mean the H4s with the sliding cover to hae the dipped and full beam in the same bulb, they won't fit your car.
    ____________________________________________
    VW Golf Mk.V 2.0tdi 4Motion
    VW Golf Mk.IV 1.4i
  3. Re: Single beam Xenon or Bi beam for A4 (B6)
    Hanny Guest
    Quote Originally Posted by raju6000 View Post
    Hi everyone,
    Thanks in advance
    Single Beam HID Conversion Kits are for headlights that use a seperate Halogen bulbs for the dipped and High Beam.
    Bi-Xenon Beam HID Conversion Kits are for headlights that use one single bulb for both dipped and high beam
    You may want to research as to legalities with regards post HID upgrades etc. Dont want to say any more as this is a 'hot debate' subject on some forums
    Hope this is of help.
  1. B6 Dipped beam
    By m12oby in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-09-2009, 09:10 PM
  2. How To How do I replace the low beam HID bulb on a 03 W8
    By rg0115 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-07-2009, 04:35 PM
  3. Wishbone Front / Rear Axle Bush which brand
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 12:27 AM
  4. Xenon headlights for my B6
    By lucas88 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-04-2008, 10:16 PM
  5. B5 v B6
    By claranet in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-02-2008, 09:53 PM
