Thread: Audi a8 2003 Current gearshift program problem
Results 1 to 10 of 12
  1. Audi a8 2003 Current gearshift program problem
    Oct 2009
    estonia
    Hello! English is not my native language, and I use a translation program for assistance and I hope that you understand what I write.
    Audi A8 4.0 TDI 2003
    When the engine reaches operating temperature, the gear box does not change and the engine will work half power. Transmission doun´t have trouble codes.
    Transmission ECU:
    vag:
    Display group 002:
    Display zone 1: Current gearshift program 1-45.
    whenever transmission goes to an emergency mode shows 47. Can not find the matches for this. Shift programme for Tiptronic function working properly.
    Engine ECU gives intake manifold runner control fault. Do not believe that it is a problem. If anyone has ideas to help solve the problem, let me know
  2. Re: Audi a8 2003 Current gearshift program problem
    Aug 2008
    hi looks like its in limp mode you need to fix engine fault first
    do full scan of car and post that on here
    paul
  3. Re: Audi a8 2003 Current gearshift program problem
    Oct 2009
    estonia
    VIN: WAUZZZ4E54N005496 Mileage: 146940km/91304miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    07-Control Head -- Status: OK 0000
    11-Engine II -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    1E-Media Player 2 -- Status: Malfunction 0010
    25-Immobilizer -- Status: Malfunction 0010
    28-HVAC, Rear -- Status: OK 0000
    34-Level Control -- Status: Malfunction 0010
    37-Navigation -- Status: OK 0000
    38-Roof Electronics -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    55-Xenon Range -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    57-TV Tuner -- Status: OK 0000
    61-Battery Regul. -- Status: Malfunction 0010
    62-Door,Rear Left -- Status: OK 0000
    67-Voice Control -- Status: OK 0000
    76-Park Assist -- Status: Malfunction 0010
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: None
    Part No SW: 4E0 910 409 C HW: 4E0 907 409 B
    Component: 4.0L 4V/TDI G000AGMŖ0020
    Revision: <> Serial number: AUX3Z0C5117862
    Coding: 0010773
    Shop #: WSC 02313 785 00200
    2 Faults Found:
    19591 - Intake Manifold Runner Control: Lower Stop not Reached
    P3135 - 000 - -
    18282 - Valve for Torque Support Mount: Short to Plus
    P1874 - 000 - -
    Readiness: 0 0 X X X
    Address 02: Auto Trans Labels: 09E-927-156.lbl
    Part No SW: 4E0 910 156 J HW: 09E 927 156 A
    Component: AG6 09E 4,0LTDI RdW 0040
    Revision: 00000001 Serial number: 0014836
    Coding: 0000001
    Shop #: WSC 32506 134 08485
    No fault code found.
    Address 03: ABS Brakes Labels: 4E0-910-517.lbl
    Part No SW: 4E0 910 517 A HW: 4E0 614 517 A
    Component: ESP 5.7 allrad H29 0420
    Coding: 0008557
    Shop #: WSC 32506 000 00000
    1 Fault Found:
    00003 - Control Module
    014 - Defective
    Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
    Part No SW: 4E0 910 131 HW: 4E0 909 131
    Component: FBS AUDID3 H02 0120
    Revision: 01203602 Serial number: AUX3Z0C5117862
    Coding: 0262144
    Shop #: WSC 02311 785 00200
    Part No: XXXXXXXXXXX
    Component: ELV XXXX
    1 Fault Found:
    00668 - Supply Voltage Terminal 30
    002 - Lower Limit Exceeded - Intermittent
    Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
    Part No SW: 4E0 910 729 H HW: 4E0 035 729 A
    Component: Interfacebox H43 0770
    Revision: 00000000 Serial number: 300FB037522155
    Coding: 0000002
    Shop #: WSC 00000 785 00200
    Part No: 4E0 910 609
    Component: Bedienteil MMI H41 0010
    Address 08: Auto HVAC Labels: None
    Part No SW: 4E0 910 043 HW: 4E0 820 043 A
    Component: KLIMAAUTOMAT 015 0240
    Revision: 00000017 Serial number: 00000000019772
    Coding: 0006233
    5 Faults Found:
    01207 - Control Module for Auxiliary Heater
    004 - No Signal/Communication
    00066 - Right Rear Footwell Heater (Z43)
    012 - Electrical Fault in Circuit
    00819 - High Pressure Sensor (G65)
    00710 - Defroster Flap Positioning Motor (V107)
    003 - Mechanical Failure - Intermittent
    00728 - Potentiometer in Positioning Motor for Left-Hand Central Vent (G136)
    010 - Open or Short to Plus - Intermittent
    Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
    Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
    Component: ILM Fahrer H11 0100
    Coding: 0001001
    Part No: 4E1 910 113 B
    Component: Wischer WWS D3 H50 0400
    Coding: 00000038
    Shop #: WSC 32506
    2 Faults Found:
    02601 - Drivers Side Footwell Light (W9)
    00908 - Control Module for Wiper Motor
    Address 11: Engine II Labels: None
    Component: 4.0L 4V/TDI G000AGSŖ0020
    Coding: 0010773
    1 Fault Found:
    17426 - Intake Manifold Runner (Bank 2): Lower limit not reached
    P1018 - 000 - -
    Address 15: Airbags Labels: 4E0-910-655-84.lbl
    Part No SW: 4E0 910 655 HW: 4E0 959 655
    Component: Airbag 8.4E+ H09 0940
    Coding: 0431707
    1 Fault Found:
    01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
    011 - Open Circuit - MIL ON
    Address 16: Steering wheel Labels: 4E0-910-549.lbl
    Part No SW: 4E0 910 549 HW: 4E0 953 549
    Component: Lenksäulenmodul H09 0030
    Coding: 0012141
    Shop #: WSC 00000 000 00000
    Component: Lenkradmodul H02 0050
    Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
    Part No SW: 4E0 910 900 HW: 4E0 920 900 F
    Component: KOMBIINSTR. VDO H42 0070
    Revision: D08 Serial number: AUDID3C5001744
    Coding: 0000003
    Shop #: WSC 00200 522 67675
    Address 19: CAN Gateway Labels: 4E0-910-468.lbl
    Part No SW: 4E0 910 468 HW: 4E0 907 468 A
    Component: Gateway H07 0050
    Revision: 07 Serial number: 13003036110E6C
    Coding: FCFEFFC42B7504
    Shop #: WSC 00000 128 00289
    Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 111 C HW: 4E0 035 111
    Component: CD-Changer H43 0340
    Serial number: AUZ5ZBC1014105
    1 Fault Found:
    02261 - Media Player; Position 1 (R118)
    014 - Defective - Intermittent
    Address 25: Immobilizer Labels: 4E0-910-131.lbl
    Coding: 0262144
    Component: ELV XXXX
    XXXXXXXXXXX ELV XXXX
    1 Fault Found:
    Address 28: HVAC, Rear Labels: None
    Part No SW: 4E0 910 158 HW: 4E0 919 158
    Component: KLIMA-STG. FOND 015 0200
    Revision: 00000012 Serial number: 00000000008021
    Coding: 0000000
    Address 34: Level Control Labels: 4E0-910-553.lbl
    Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
    Component: LUFTFDR.-CDC H05 4290
    Coding: 0015510
    2 Faults Found:
    00778 - Steering Angle Sensor (G85)
    008 - Implausible Signal - Intermittent
    01316 - ABS Control Module
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 887 T HW: 4E0 919 887 C
    Component: MNS ECE H41 1030
    Revision: 00000000 Serial number: 305FT037536298
    Address 38: Roof Electronics Labels: 4E0-910-135.lbl
    Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
    Component: Dachknoten D3 H01 0090
    Revision: noten D3 Serial number: 00000328100053
    Coding: 0069280
    Address 42: Door Elect, Driver Labels: None
    Part No SW: 4E1 910 802 A HW: 4E1 959 801 A
    Component: Türsteuer.FSmBRM004 0080
    Coding: 0002337
    Address 46: Central Conv. Labels: 4E0-910-289.lbl
    Part No SW: 4E0 910 289 A HW: 4E0 907 289
    Component: Komfortgeraet H03 0030
    Revision: 00300003 Serial number: W040306270038
    Coding: 0000616
    Part No: 4E0 910 853
    Component: Heckdeckel P14H06 0070
    1 Fault Found:
    01134 - Alarm Horn (H12)
    Address 47: Sound System Labels: 4E0-910-223.lbl
    Part No SW: 4E0 910 223 G HW: 4E0 035 223 A
    Component: DSP-Amp.-High H00 0360
    Serial number: šÄ=Ū
    Coding: 0000022
    Address 4F: Centr. Electr. II Labels: None
    Part No SW: 4E0 910 280 HW: 4E0 907 280 A
    Component: ILM Beifahrer H07 0070
    Revision: Serial number: 00000000020915
    Coding: 0010101
    1 Fault Found:
    02270 - No Acknowledgment from Limit-Shut Off at Display Unit Deployment
    Address 52: Door Elect, Pass. Labels: None
    Part No SW: 4E1 910 802 A HW: 4E1 959 802 A
    Component: Türsteuer.BFmBRM004 0080
    Coding: 0002337
    Address 53: Parking Brake Labels: 4E0-910-801.lbl
    Part No SW: 4E0 910 801 A HW: 4E0 907 801
    Component: EPB AV1C1010 H01 1010
    Revision: AV1C1010
    Coding: 0000431
    Shop #: WSC 61212 134 80254
    2 Faults Found:
    02439 - Right Parking Brake Motor Hall Sensor
    004 - No Signal/Communication - MIL ON
    02596 - Rear Brake Pads Worn
    Address 55: Xenon Range Labels: None
    Part No SW: 4E0 910 357 HW: 4E0 907 357
    Component: Pre-AFS H01 0030
    Coding: 0000002
    5 Faults Found:
    01539 - Headlights Not Adjusted
    005 - No or Incorrect Basic Setting / Adaptation - MIL ON
    02233 - Left Headlight Power Output Stage (J667)
    02234 - Right Headlight Power Output Stage (J668)
    01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
    02235 - Stationary Cornering Lamp (Left) (M51)
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 C HW: 4E0 035 541
    Component: TUNER EU/US/RDW H41 0290
    Revision: 00000000 Serial number: 304GN037535941
    Coding: 0000001
    Address 57: TV Tuner Labels: 4E0-910-146.lbl
    Part No SW: 4E0 910 146 C HW: 4E0 919 146
    Component: TV analog TUNER H12 0210
    Revision: 00000033 Serial number: 00000000000000
    Coding: 0001001
    Address 61: Battery Regul. Labels: 4E0-910-181.lbl
    Part No SW: 4E0 910 181 HW: 4E0 915 181
    Component: ENERGIEMANAGER H02 0160
    Revision: 00000000 Serial number: 00000000010227
    Part No: 000 915 105 AK
    Component: von VA0 0404051241
    Coding: 303030393135313035414B56413030343034303531323431
    1 Fault Found:
    Address 62: Door,Rear Left Labels: 4E0-910-802.lbl
    Part No SW: 4E0 910 802 HW: 4E0 959 801 A
    Component: Türsteuer.HL BRM004 0090
    Coding: 0002337
    Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
    Part No SW: 4E0 910 753 F HW: 4E0 035 753
    Component: SDS 3500 DE H43 0380
    Revision: 00000000 Serial number: 00000306250036
    Shop #: WSC 12336 024 394758
    Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
    Part No SW: 4E0 910 802 HW: 4E0 959 802 A
    Component: Türsteuer.HR BRM004 0090
    Coding: 0002337
    Address 76: Park Assist Labels:
    Address 77: Telephone
    Cannot be reached
  4. Re: Audi a8 2003 Current gearshift program problem
    Aug 2008
    theres lots of things going on
    first thing is to clear all fault codes and see what codes come back
    looks like you have a common electrical fault
    check this link out and use diagnostics codes link on left to enter a your codes and it might give you some answers
    http://wiki.ross-tech.com/index.php/Main_Page
    paul
  5. Re: Audi a8 2003 Current gearshift program problem
    May 2007
    knee deep in clunge
    14 Post(s)
    SORT THIS OUT
    Coding: 0010773
    2 Faults Found:
    P3135 - 000 - -
    Very common.the manifold flaps break away and this requires new intake manifolds and motors.This will reduce torque and throttle response so hence the gearchange will be affected
    Dont worry about this 18282 - Valve for Torque Support Mount: Short to Plus
  6. Re: Audi a8 2003 Current gearshift program problem
    Oct 2009
    estonia
    Quote Originally Posted by saabsalltheway! View Post
    paul
    These error codes can not be deleted.
    Thank you for the link!
  7. Re: Audi a8 2003 Current gearshift program problem
    Oct 2009
    estonia
    Quote Originally Posted by a8 tech View Post
    SORT THIS OUT
    Coding: 0010773
    2 Faults Found:
    P3135 - 000 - -
    P1874 - 000 - -
    I have repeatedly seen the error of ntake Manifold Runner Control but have not met that it was the warm engine and gearbox problems arise. 3.0 TDI is also typically result in power loss with a cold and warm engine but gearbox does not go the emergency mode. And if intake manifold runner control fault causes gearbox emergency mode then why olny when the engine has reached working temperature? Its not dufficult change intake manifold whit runner control´s but quite expensive. About 1000.-eur one side.
  8. Re: Audi a8 2003 Current gearshift program problem
    Oct 2009
    Estonia
    Mhh, that's interesteing. Does Audi use those flaps for some other reason than BMW?
    LINK: http://forums.5series.net/lofiversio...hp/t70452.html
    Swirl flaps stick in open position: Deterioration in exhaust gas characteristics in lower speed ranges otherwise no effect.
    Swirl flaps stick in closed position: Power loss of approx. 10 % at higher engine speeds.
    Audi A8 4.0tdi:
    There are variable, two-position swirl flaps integrated into the intake tract. They can be used to adjust the air movement according to the prevailing engine speed and load. High swirl at a low engine load optimises the combustion process as, conversely, does low swirl at a high engine load. In practise this means that a closed swirl duct at low load increases swirl, while open ducts at high load boost cylinder charging.
  9. Re: Audi a8 2003 Current gearshift program problem
    Aug 2008
    if you look at your own scan results it shows no fault with the auto transmission
    so you need to sort the engine faults first
    i even looked at a landrover free lander today with loss of power and a missfire sorted the missfire and that sorted the loss of power untill i took it for a test drive and it started missfireing and loss of power turns out to be a fault with the abs and traction control
    dont look for problems just fix the ones in your scan results
    paul
  10. Re: Audi a8 2003 Current gearshift program problem
    Oct 2009
    estonia
    I found a solution to the problem Fuel temperature goes above the permitted limit. Fuel temperature sender seems to be ok. I tried second sensor and the temperature was the same. Today I will try to identify the cause of the overheating of the fuel
  1. Aluminium a5 coupe prototype shows the lighter side of audi
    Last Post: 04-10-2009, 02:16 PM
  2. Can I fit Satnav to my new A4 Cab
    By car@fmcneill.fr in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-04-2008, 10:09 AM
  3. Road-ready Audi R8 super car wows Paris show
    Last Post: 28-09-2006, 09:46 PM
  4. Replies: 0
    Last Post: 23-02-2006, 02:26 PM
  5. Replies: 0
    Last Post: 23-10-2005, 11:19 AM
