Thread: Swap RCD510 for RNS510
Results 1 to 10 of 13
  1. Swap RCD510 for RNS510
    Aug 2009
    Amersham
    If I were to buy a RNS510 would it be a simple swap out for the RCD510 or does it require additional wiring to supply the Sat Nav signal ? Thinking of selling my RCD on ebay and buying the RNS if it's easy to do.
  2. Re: Swap RCD510 for RNS510
    Jul 2009
    Glasgow
    The only additional wiring is the GPS receiver that plugs into the RNS510. You don't have to route this anywhere. It can sit on a wee ledge above the stereo hidden away.
  3. Re: Swap RCD510 for RNS510
    Aug 2009
    Amersham
    I presume the GPS reciever does not have to have an external connection then? I thought thats how they worked?
  4. Re: Swap RCD510 for RNS510
    Feb 2007
    Yuo may also have to get the dealer or a friend with vagcom to pair the RNS to the multifunction display in the instrument cluster and any mutli function steering wheel.
    I might be interested in your RCD510 if you go ahead
  5. Re: Swap RCD510 for RNS510
    Aug 2009
    Amersham
    Thanks, I will do some research on the costs.
  6. Re: Swap RCD510 for RNS510
    Jul 2009
    Glasgow
    Quote Originally Posted by bozal View Post
    It has an external GPS receiver but with most GPS receivers they don't need to be external for it to function fine.
    Most just tuck theirs on the wee ledge above the stereo.
    My TomTom works perfectly well tucked in where the ash tray is without an external receiver.
  7. Re: Swap RCD510 for RNS510
    Feb 2007
    The GPS aerial is a small black box that you can location on the little shelf within the stereo aperture in the dash - provide there is no metal above it it will work fine, and the shelf/ledge is a proven location. You need to ensure the unit you buy comes with the aerial and the mapping DVD. You also need to check the version A, B or C - i guess you will be B or C but you do need to check. There are firmware updates that can be done, but there may be a risk of freezing the unit if not completed correctly.
    Also check who you buy your RNS510 from - one guy on golfgtiforum had a mare with his seller, needing 4 units to find one that was acceptable quality. Some ebay come from lithuania, although they seem to be more reliable in quality !
  8. Re: Swap RCD510 for RNS510
    Aug 2009
    Amersham
    Thanks all. I clearly need to check carefully any e-bay seller before I go ahead.
  9. Re: Swap RCD510 for RNS510
    Jul 2009
    Glasgow
    Bozal there are a few guys on golfgtiforum MK6 section who bought on eBay from Latvian sellers and were delighted. I think they got them for £550. Have a search of that board.
    And yeah you may have to get VAGcom activated but some are saying theirs was already activated.
  10. Re: Swap RCD510 for RNS510
    Feb 2007
  1. Please Help RCD510 skipping first part of every song on MP3's
    By smipx013 in forum In Car Entertainment
    Last Post: 02-08-2009, 06:47 PM
  2. Please Help Passat Headlight swap, is it posible to swap early / late over?
    By scotlandstu in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-05-2009, 11:26 AM
  3. Question Rcd510
    By wacits in forum In Car Entertainment
    Last Post: 14-04-2009, 11:53 PM
  4. Grille swap
    By CMcK in forum Golf MK5 - 2004 - 2009
    Last Post: 20-05-2008, 06:16 PM
  5. Golf MK3 TDI; VR6 rear axle swap
    By tornadored7 in forum Golf MK3 - 1993 - 1999
    Last Post: 30-08-2007, 08:58 PM
