Thread: Passat Estate Tailgate Problem
  1. Passat Estate Tailgate Problem
    Feb 2007
    I have an Estate 2.3 V5 and the central locking has failed on the tailgate. It's locked in the closed position and I can see no way of gaining entry to this part of the car to try and remedy the problem. Is there any way of manually releasing the door, so I can remove the panel to investigate the problem? I've crawled through interior of the car, but there seems no way of removing the panel with the tailgate closed.
    Please help!
    Thank you.
    Passat B5 V5 Auto Tip Highline
    Just about to hit 100k!
    Mar 2007
    West Mids
    Hello,
    Dont you have a lock on the underside where the button to open the tailgate is?
    You should be able to open it with the key.
    Nick.
    Feb 2007
    There is a lock on the tailgate but it doesn't seem to mechanically release the door, it just operates the central locking or dead-locks the door (opens/closes windows).
  4. Passat Tailgate lock
    Apr 2006
    You can turn the key lock to a third position which mechanically releases the tailgate lock mechanism.
    I found that the release handle which is under the moulded handle you open the tailgate with had seized but you could still open the tailgate by one person unlocking it on the drivers door switch and another immediately opening the tailgate using the normal handle on the tailgate.
    Feb 2007
    I resolved the problem by climbing inside the rear of the car and partially removing the large peice of plastic trim on the lower part of the tailgate. The two top scres could not be accessed with the door closed, so I had to bend the plastic, squeeze my arm in and feel for the mechanism. It transpires that the solenoid had stopped working probably due to dirt and lack of lubrication. At least the DIY approach saved a few pounds as I expect the local VW dealer would have been charging a lot of money for that repair.
    As to the lock mechanically releasing the door, I just can't get that part to work. The lock on the tailgate turns anti-clock to unlock the central locking, clock-wise (to 1 O'clock) to lock central locking and clock-wise again (to 3 O'clock) to dead-lock the tailgate. There seems to be no way to mechanically release the door.
    Apr 2006
    I found there was a little actuator in the off side of the tailgate. When you go to open the tailgate from the drivers door it pulls a cable which unlatches the tailgate lock, but it only unlocks for about three seconds and then releases back to a latched position. When you squeeze the release handle it actuates this actuator again and allows you to open the tailgate
  1. Passat Estate tailgate lock
    By waylonbuddy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-07-2007, 12:21 AM
  2. Mk4 golf tailgate lock problem
    By sandancer in forum Golf MK4 - 1999 - 2004
    Last Post: 28-05-2007, 09:49 AM
  3. Passat estate - tailgate adjustment
    By vw18estate in forum Archive posts
    Last Post: 13-02-2007, 10:58 PM
  4. 02 Passat Estate Sport oil problem
    By Scott Grove in forum Archive posts
    Last Post: 27-09-2006, 04:06 PM
  5. Tailgate doesn't lock (1.8T sport estate)
    By davegwynn in forum Passat - Archive Topics
    Last Post: 17-02-2006, 01:41 PM
