Thread: Handbrake adjustment
Results 1 to 9 of 9
  1. Handbrake adjustment
    Sep 2008
    My Alhambra handbrake needs to be adjusted, lots of clicks are required to get the handbrake to bite and even then, it is not tight enough.
    I assume there is adjustment somewhere in the cables, but where?
    I have pulled the trim off inside the car but could not find any ajustment. Is it under the car?
  2. Re: Handbrake adjustment
    It is self adjusting
  3. Re: Handbrake adjustment
    Sep 2008
    I understand that there is a self adjusting mechanism in the caliper, but surely there must be an adjustment in the cable to allow for cable stretch?
  4. Re: Handbrake adjustment
    There isn''t
  5. Re: Handbrake adjustment
    Sep 2008
    FYI - there is.
    Between the first part of the handbrake cable and where it splits down each rear suspension arm, there is an adjuster.
    Thanks for your replies though.
  6. Re: Handbrake adjustment
    That is not designed as a means to adjust the hand brake Due to the automatic rear wheel brake adjustment there is no requirement to adjust the handbrake after making new/initial adjustment.
  7. Re: Handbrake adjustment
    Sep 2008
    Except for perhaps the cable stretching, as happens with all handbrake cables?
  8. Re: Handbrake adjustment
    Quote ( lots of clicks are required to get the handbrake to bite and even then, it is not tight enough.) i doubt very much that the cables have streched that much
  9. Re: Handbrake adjustment
    Jun 2009
    Sheffield UK
    Could worn discs or pads be an issue?
  1. How To Handbrake adjustment
    By Andante in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-07-2009, 12:25 AM
  2. Passat Electronic Handbrake (doomsday scenario)
    By meoman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-06-2009, 05:52 PM
  3. Handbrake adjustment
    By antonb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-02-2008, 03:47 PM
  4. how the handbrake works !
    By carl s in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-07-2007, 09:20 PM
  5. Passat Electronic Handbrake Problems
    By wildinthecountry in forum Passat - Archive Topics
    Last Post: 08-10-2006, 05:39 PM
