Thread: Tdi sport drivers door won't open from outside
Results 11 to 20 of 34
  1. Re: Tdi sport drivers door won't open from outside
    Feb 2009
    I also have this problem, exactly as REVIT describes it. It would appear to be a mecanical problem and not electrical, which is good as i would expect this is a job for a mechanic and not a specialist auto electrician or vw dealer.££££
    Thanks guys
  2. Re: Tdi sport drivers door won't open from outside
    Stoke on Trent, UK
    I had this on my 07 plate estate a couple of weeks ago - it was a broken actuator and cable - replaced under warranty so I can't tell you cost or how easy it is (sorry!).
  3. Re: Tdi sport drivers door won't open from outside
    May 2009
    uk
    see my post.
    i've had same problem today and worked out how to open door from inside.
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=84254
  4. Unhappy Re: Tdi sport drivers door won't open from outside
    May 2009
    wirral
    final update --- £140 labour and part ouch!!!
  5. Re: Tdi sport drivers door won't open from outside
    I've just had this problem with front passenger door, ie pulling the outside handle does nothing, but it opens OK from the inside.
    VW quoted almost £200 for the repair, but just before it was due in the door started working normally again, so touchwood it was just a temporary glitch that has righted itself.
    I'm not holding my breath though
    06 Passat 2.0 TDi 140 SE Estate, Reflex Silver, 125,000 miles
  6. Re: Tdi sport drivers door won't open from outside
    Nov 2008
    I had a similar problem about Nov/Dec last year. Front passenger door wouldn't open from outside but would from the inside. It was under warranty so phoned the dealer. I was told that it was a 'long job' as the whole door has to be stripped but not a problem as under warranty. Just before it went into the dealer the problem disappeared. That was until last week when guess what? The passenger door wouldn't open from the outside again! Do you think it's the weather???
  7. Re: Tdi sport drivers door won't open from outside
    #17
    This has happened to me a couple of times. The immediate remedy for me was to open the car windows with the key fob and put your hand through to open it from the inside.
    Now, mine sorted itself out without any cost, on both occcasions. (I figured that I'd been a bit hasty trying to open the door just after I had unlocked it and guessed therefore that the system had got itself confused.)
    So, my remedy was to keep opening, locking, unlocking, opening, from inside, from outside, until the external door handle re-engaged. It's worked both times, and I've not had it happen again for the best part of a year. It's worth a try before spending money on it!
  8. Re: Tdi sport drivers door won't open from outside
    #18
    May 2009
    Wirral
    I have also been having this problem. Passenger door cannot be opened from outside.
    I found that if I messed about with opening and shutting the door (from inside) it would eventually start working again for a while. It's currently not working again so will give it another whirl tomorrow.
    Interesting what an earlier poster says about the cable being stretched, I wonder if thats the problem?
    2006 Passat Saloon 2.0 SE TDI SatNav
  9. Re: Tdi sport drivers door won't open from outside
    #19
    May 2009
    Essex
    My drivers dore has done exactly the same thing. Now after opening the windows and opening the door from the inside for a couple of weeks it has decided to start working again!!
    Think I will wait for some warmer weather before I take the door apart to find the problem.
  10. Re: Tdi sport drivers door won't open from outside
    #20
    Quote Originally Posted by tommyweaves View Post
    Indeed, I think my glitch arose when a passenger tried to open the door when I was unlocking it, but I wasn't sure if this was a coincidence, but your experience seems to suggest there was a connection.
    The fact that others are now saying that the prolem has recurred after seemingly rectifying itself doesn't fill me with joy though
  1. tdi 140 Sport or 170 Sport?
    By Agent_Trig in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 03-08-2007, 07:44 PM
  2. ISOFIX on 1.9 TDI Sport estate?
    By neal in forum Passat - Archive Topics
    Last Post: 08-01-2007, 10:34 AM
  3. PRICES OF NEW TOUAREG ANNOUNCED AHEAD OF MARCH LAUNCH
    Last Post: 02-01-2007, 08:22 PM
  4. ADVANCED NEW FOUR-CYLINDER PIEZO TDI ENGINE
    Last Post: 17-05-2006, 08:14 PM
  5. A3 Range Update
    Last Post: 14-02-2005, 11:35 PM
