Thread: A4 2005 a4 balance shaft
Page 6 of 6 FirstFirst ... 456
Results 51 to 55 of 55
  1. Re: A4 2005 a4 balance shaft
    #51
    Oct 2009
    Londonderry , N. Ireland
    The Air Con pump is another common fault - I was quoted £850 by Main dealer again on an 05 with only 60k miles. Audi not too worrried about customer care on this one- should have been a recall or replacement FOC.
  2. Re: A4 2005 a4 balance shaft
    #52
    Jan 2009
    NORTHERN IRELAND
    Quote Originally Posted by irishejit View Post
    right just back from the VW dealer.they had it up on the ramp and totally stripped down.the noise is from the air con pump.at least its not the oil shaft fault,so now need to go find how much a pump is.
    Good news,well better than the worst anyway. I got my pump off e bay and it was almost new,Audi will give you the exact part number but I know my new one came out of an 07 A4 with a different part number but the only adjustment is to connect the wiring to the top instead of bottom,or possibly bottom as opposed to top. It was a company called parts-direct-uk on ebay. and was only 100 quid from a write off with only 6k miles. They didnt list as delivering to NI but will for a fee , i think 25£.
    2 0 0
  3. Re: A4 2005 a4 balance shaft
    #53
    Jan 2009
    Does the 2006 1.9 TDI BRB engine have this same problem?
  4. Re: A4 2005 a4 balance shaft
    #54
    Sep 2016
    glasgow
    joining this late as i stupidly bought a 2007 A4 convertible last year with 60K on the clock , used it for 500mils - red oil light came on, brakes seized etc same as everyone else
    had a quote from an audi garage of £2500-£3500 to replace hex balancer shaft assembly and possible turbo if needed - had no money so got car into our garage at home and left it till this week - took it to garage, i sourced the hex kit for £215 garage
    charging £1000 labour, got call 2 days later to say all fitted but turbos gone - another £750 required - HOWEVER NOT TO CONFIDENT THAT THIS WILL BE THE CAR FIXED AS ENGINE SOUNDS NOISY - no idea what to do now
    anyone else got to this stage ?
  5. Re: A4 2005 a4 balance shaft
    #55
    Mar 2017
    Did the garage not check the main bearings and conrod bearings nearest the gearbox when it was all apart?? They should have, as these are the ones which fail first, and would have picked up on damage before putting it all back together. It would have only taken them an extra 30 mins and 4 new bolts from Audi (they are single use bolts).
    If there is damage to the main bearings / conrod bearings then the crank will likely be damaged also which will mean it needs a regrind or a new (used) engine, as getting the crank reground is basically a full engine rebuild job, everything has to come out.
  1. Ultra-economical audi a4 tdi gets the ‘e’ treatment
    Last Post: 11-07-2009, 08:11 PM
  2. Uk Specification Audi A4 Launched In Frankfurt
    Last Post: 16-09-2007, 09:25 PM
  3. Latest Audi A4 Specification Now Sounds Even Better
    Last Post: 06-07-2006, 09:25 PM
  4. Fast forward to spring with new A4 Cabriolet S line range
    Last Post: 02-02-2005, 09:26 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
