Thread: Golf MK4 COOLANT, anti-freeze replacement
  1. Golf MK4 COOLANT, anti-freeze replacement
    Aug 2008
    Hi, could anyone give me any tips on replacing the coolant on my car MK4 Golf PD150, where is the drain plug on the rad??, is ther an additional drain plug on the system, how to eliminate air lock? is there a way of removing unwanted air from the system?? etc, I already have the correct pink long life anti-freeze. Thanks in advance
  2. Re: Golf MK4 COOLANT, anti-freeze replacement
    SHEFFIELD
    Drain it by removing bottom hose,these dont really airlock that much to be honest and if they do just do the normal let it get warm with reservoir cap off.You could also flush through with just normal water 1st if you wanted to make sure all deposits are out of system then drain again,then put your antifreeze in.How come your changing the antifreeze?
    I dont work here for the pay,or the enjoyment,so why do i work here
  3. Re: Golf MK4 COOLANT, anti-freeze replacement
    Oct 2009
    Essex
    Good point why are you changing it? Have you checked the gravity?
    There's a fine line between genius and insanity!
  4. Smile Re: Golf MK4 COOLANT, anti-freeze replacement
    Aug 2008
    Hi Tony, cheers for the info, sounds simple, changing the antifreeze as a matter of course, no other reason, I could just top it up I suppose. All the best Andy
  1. Volkswagen launches new range of highly efficient golf models
    Last Post: 03-07-2009, 07:48 PM
  2. MK4 Golf TDI starts from cold with temp sender disconnected
    By peteheat in forum Golf MK4 - 1999 - 2004
    Last Post: 10-05-2009, 01:50 PM
  3. New Golf Estate Set To Break Cover At Geneva Motor Show
    Last Post: 27-02-2007, 09:15 PM
  4. Golf TDI MK 4 coolant loss problem
    By siputt in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-02-2007, 11:30 AM
  5. 24 MILLIONTH GOLF ROLLS OFF LINE - EXPANDED UK GOLF RANGE
