Thread: Fan Belt Tensioner A6 1.9TDI SE
  1. Question Fan Belt Tensioner A6 1.9TDI SE
    Mar 2009
    Galway, Ireland.
    Howdy!
    There is an awful squealing out of my fan belt when i turn the steering, especially on tarmac when the steering is under more pressure... It also is very noisy when its cold, but isn't as bad when it heats up.
    I'm being told I've to replace the fan belt tensioner because it goes on them all, but i'm wondering, is it not possible to simply tighten the belt, because the belt itself seems fine!
    I always understood it was a simple enough job to tighten a fan belt without having to replace stuff every time it loosens!?
    2002 Audi A6 1.9 TDI Lim. Eds, 1980 Ford Escort MKII Elite 2 door.
  2. Re: Fan Belt Tensioner A6 1.9TDI SE
    it could be the bearings are gone in the tensioner pulley meaning it cant turn freely giving the squealing belt.
    I had to get mine replaced a while back, on my engine AWX the tensioner is a 3 part unit (a pulley, a damper and a bracket to hold the tensioner)
    you might just have to replace the pulley but the bracket was slightly warped on mine so that had to be replaced on mine too.
    if the belt is squealing it could be the clutch pulley in the alternator has siezed, theres lots of posts on here about that one too.
    2016 A6 2.0 TDI S-Line
    1969 Triumph Spitfire (In pieces )
  3. Re: Fan Belt Tensioner A6 1.9TDI SE
    1840 Post(s)
    That is normally the alternator one way clutch.
    The belt is auto tensioning and cannot be manually adjsusted.
  4. Re: Fan Belt Tensioner A6 1.9TDI SE
    Mar 2009
    Galway, Ireland.
    I got the pulley on the altenator done recently, because there was a squeaking. There was no problems until a short time after, so I brought it back to the garage thinking that it was the altenator pulley giving trouble again, but that was fine, it was how the fan belt tensioner is on the way out and thats how the squeaking started again! I was told it is 200 euro for just the tensioner alone, then labour after that. I was just wondering if it was possible to tighten it like the good aul days!? obviously not so!
  1. Court Hearing - Information required...
    By motyourcar in forum Chat - Anything with wheels
    Last Post: 17-08-2011, 09:31 PM
  2. ...change a timing belt on an Audi A6 1.9TDI 110
    By se-automotive in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 07-10-2009, 04:12 PM
  3. 1.9TDI Serpentine belt
    By tone44 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-03-2008, 06:24 PM
  4. Belt HELP! Fan Belt?
    By whitelockben in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-06-2007, 08:57 PM
  5. Ultimate specification for A6 Avant final edition models
    Last Post: 18-10-2004, 07:29 PM
