Thread: 3.0 TDI problem
Results 11 to 20 of 38
  1. Re: 3.0 TDI problem
    May 2007
    knee deep in clunge
    14 Post(s)
    never noticed Toff but suspect intake manifold change over returning to its open position
  2. Re: 3.0 TDI problem
    london/ UK
    Quote Originally Posted by a8 tech View Post
    Thats the one, does it in any v6 tdi engine i've worked on...
  3. Re: 3.0 TDI problem
    Jun 2008
    Manchester
    Fault codes guys...will be changing fuel filter. Can faulty fuel filter throw up all these faults ?
    A4 3.0TDIQ S-Line
  4. Re: 3.0 TDI problem
    May 2007
    knee deep in clunge
    14 Post(s)
    Yes checking the rail pressure switch can also help by simply disconnecting the sensor on the right bank rail the fuel pressure defaults and performance will return if the sensor is faulty.
    The high pressure pump driven by the aux belt can fail internally causing swarf to circulate around the fuel system.
    When the filter blocks the fuel supply from the pressure pump the high pressure sensor reads a drop so the required rail pressure cant be reached for injection.
    The filter issue affected B7 and 4F A6 2.7 and 3.0 common rail and the manufacturer of the filters has since been replaced although no recall was issued only a few vehicles were affected but I replaced a filter for this very issue on Monday
  5. Re: 3.0 TDI problem
    Jun 2008
    Manchester
    Thanks A8_tech getting filter changed today and see how it goes....this is the only problem I have had. I did change the fuel filter 15k miles ago as part of the service at 40k miles as indicated in the service book, could be that I got a bad one.
    Cheers Ray
    A4 3.0TDIQ S-Line
  6. Re: 3.0 TDI problem
    Jun 2008
    Manchester
    Changed fuel filter, same problem. Will look at the sensor next.
    Why would the high pressure pump fail ? i dont think this is a common fault ? are they prone to failure ? I hope its not that as that will be very expensive...surley the pump should not fail at 55k miles ?
    One of the reasons it would fail is if someone put petrol in instead of diesel due to lubrication.
    A4 3.0TDIQ S-Line
  7. Re: 3.0 TDI problem
    #17
    Jun 2009
    maidstone
    my car kept cutting out for no reason and would not start , then it would start when left but only drive for a while before cutting out again with the coil light flashing , turned out to be the main fuel pump , audi changed the one in the tank first as this was the cheaper option to start with ... all fine now but a very exspensive part to buy and fit .
  8. Re: 3.0 TDI problem
    #18
    May 2007
    knee deep in clunge
    14 Post(s)
    Quote Originally Posted by KQuattro View Post
    Ray i would suggest either the fuel delivery is poor from the pressure pump in the tank or the high pressure sender.The high pressure pump is possible but if there's insufficient pressure before the pump then high pressure pump will not produce the correct pressure required hence the fault code.
  9. Re: 3.0 TDI problem
    #19
    Jun 2008
    Manchester
    Fingers crossed then...going to book it in with Audi and see whats what.
    A4 3.0TDIQ S-Line
  10. Re: 3.0 TDI problem
    #20
    Jun 2009
    maidstone
    Mine was in audi for 3 weeks trying to sort this problem , they said they could see bubbles in the fuel line so changed to pump in the tank. however when i picked up car it cut out again within 10 miles , so they changed the high pressure pump . been a very unreliable car and the last audi i will ever own
  1. Intense TDI power - The Audi A3 TDI clubsport quattro
    Last Post: 18-05-2008, 10:12 AM
  2. Crasher can you help? mk3 TDi problem
    By chackday in forum Golf MK3 - 1993 - 1999
    Last Post: 08-05-2008, 08:50 PM
  3. Tyres & Insurance
    By Sportingmac in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 17-01-2008, 05:59 PM
  4. Change from 5sp to 6sp
    By lowndsy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-11-2007, 08:14 PM
  5. VW GOLF GT TDi - Problem!!
    By Ranger Bob in forum Golf MK4 - 1999 - 2004
    Last Post: 23-10-2007, 09:49 PM
