Thread: Sharan power steering belt
Results 1 to 10 of 14
  1. Sharan power steering belt
    Aug 2006
    About 2 months ago I changed the power steering belt on my 97' Sharan because it was making a squealing sound on full lock. Also in wet weather the belt would slip, causing problems with steering (quite serious).
    I took the forward most pulley off, leaving the rear one in place. I then installed the new belt and refitted the pulley. No positions were changed, pulleys went back in the same position. There was a noticeable difference in the legth of the old and the new belt. Old one having stretched over time.
    In the last few days the full lock sqeal has slowly started to return (too my surprise). I need to try and work out why this has happened, has something moved, did something need adjusting when I fitted it ?
    There was a bolt near the forward pulley that appeared to sit on some sort of adjusting rack/gear, is this the adjustment ? It did seem to be at its limit when I fitted the new belt so I did not touch it.
    Can anyone shed any light on this, has someone had similar problems etc....
    Cheers,
    Carl.
    Unauthorised links to websites will be removed - as per the forum rules
    Feb 2007
    hi carl i had a same problem whith mine its not the belt thats at fault you need a new power steering tenshenor not only that but you have to replace the whole of the part where the altenator is fitted it is called altenator bracket from dealers bracket is for £200 and tenshenor is $50 plus labour .i hope this info is enough for u
    Aug 2006
    Ouch, why does that part need changing, what happens to it ?
  4. Re: Sharan power steering belt
    Aug 2007
    Quote Originally Posted by renamecor View Post
    Hi there.
    Did you need to go to these legths to solve the problem??
    I have the same problem on my 97 Sharan....any tips would be a great help.
    Thanks.
  5. Re: Sharan power steering belt
    Feb 2007
    hi there fast food the reason for the p s belt screeches when you full lock it to left or right is the altenator bracket this is fitted with a p s tensener and if you look close where the altenator bracket is you will see a long kind of bar which has a friction when you turn the steering but the tensener cant pull this bar easily when it starts to get jammed .there is a nother way if you take this long bar of ang give it plenty of grease that should do the job aswell i hope you know what i am on about thanks
  6. Re: Sharan power steering belt
    Aug 2006
    Good news for eveyone with the same problem I hope, I have managed to sort this problem out.
    To clarify, the symptom is that a screeching noise comes from the power steering belt when the wheel is turned onto full lock. In the beginning it only happens on full lock, then it starts to happen when there is a little more than normal resistance on the wheels, i.e. when the car is stationary and you turn the wheel, then the best (actually WORST) is when the belt slips that much in wet weather and you go to turn the steering wheel but it is too hard and you have no power steering and the car that your better half is driving nearly goes down an embankment and onto the motorway - lovely .
    What is supposed to happen with this belt is that when it stretches, you get under the car with a couple of spanners and adjust the mechanism so it takes up the slack in the belt and everything is hunky-dorey again - only a 5 minute job, easy-peasy.
    THE PROBLEM, well on my Sharan anyway, I went a bought a new belt (£3 from german swedish. Loosen off the bolts front and back, these are what the pump pivots on the keep the tension. And then you will see that the bracket has a set of teeth built into the side of it and that one of the pivot nuts has a toothed wheel underneath, these are what do the adjusting for the tension of the belt. Problem is they are only made of soft material and the toothed nut on mine had hardly any teeth left and so could not put enough tension on. I fitted it and did the best I could, the screaching stayed away for about 2 days. Bought another belt from another place, same thing happened, I did notice that the belts being supplied always took the adjustment so close to the end that you couldn't get enough tension on them, they info stamped on them says they are 735mm long (I think).
    WHAT I DID, I went and bought a slightly shorter belt from a local engineering place, think it was 705 mm, so 20mm shorter. Because my tensioner had been worn away by heavy handed previous owners, I had to get a long bar up between the power steering pump and the engine, forcing it forward and putting tension on the belt and tigthening it up at the same time. You may want to get a friend to help.
    I tightened everything up with the new belt on and it works perfectly. No more problems.
    So in conclusion, there is something wrong with the bracket or adjuster that means that replacement belts won't fit over time. I fitted a 20mm shorter belt and everything is sorted out now.
    Hope this has helped.
  7. Re: Sharan power steering belt
    Aug 2007
    Top man.
    Great detailed reply.
    Only one question....you said the first belt you brought was 735mm and later said the shorter one you brought was a 705mm so 20mm shorter.
    I hate to be picky, especially when you have done us all a big favour with this solution. But 705mm is '30mm' shorter than the 735mm you first brought.
    Can you please confirm the last one you got was 705mm ?? or was it 715???
    It may only be a matter of 10mm, but if I have the right length in mind, when I go to find one, I will only have the need to get under the car once.
    I hope you don't mind this enquiry.
    Thanks mate, good job, well done.
  8. Re: Sharan power steering belt
    Aug 2006
    You are correct, 715mm length. But to be honest there is a lot of room for fitting numerous different sized ones.
    Carl.
  9. Re: Sharan power steering belt
    Bristol
    good work m8 !!!
    I notice on my sharan, that when i turn the wheels full lock at low speed ie getting onto my drive i get like a sqeaking almost griniding noise also ,
    Ive put my hand down on the thinner V belt and i cant turn it by hand !!!
    Im thinking it needs tensioning too ?
    and does this belt , only drive the power steering pump ?
    Advice welcomed !!
  10. Re: Sharan power steering belt
    Aug 2006
    Yes this belt only drives the power steering pump. Sounds like your belt is slipping too, you will have to check how much adjustment you have left and what condition the adjuster is in.
    Get down by the drivers front wheel, might help to jack the car up a few inches to make things easier. The power steering pump sits at the front of the engine and there will be a bracket with little teeth on the side, this is only about 1 to 1 1/2 inches long, the teeth point downwards. Below it you will see a bolt head, this bolt head is holding a toothed wheel in place. The the teeth on the toothed wheel should be in mesh with the teeth on the bracket. Dependant on the position of these adjusting parts in relation to each other will depend on whether you have any adjustment left. Bascically the further to the right the lower toothed wheel is, then the less adjustment you have.
    If you feel that there is room for some adjustment, then get your spanners out as its a 5 minute job. Now I think you need a 13mm spanner or socket and a 17mm open ended spanner. Loosen off the bolt that is holding the toothed wheel, and also the bolt around the back, only loosen them, do not take them out. Now take the open ended spanner and fit it onto the toothed wheel. Turn the toothed wheel so that the power steering pump pivots away from the engine and the toothed wheel moves to the right. This will increase tension on the belt. Once you have tensioned it, tighten everything back up and give it a test. If you have run out of adjustment or it still slips, then you probably have one of the problems mentioned in my other post.
  1. How much is a timing belt for a sharan.........
    By ziggi in forum Touran - Sharan - Caravelle
    Last Post: 05-09-2011, 09:29 PM
  2. My Sharan needs a new cam/timing belt
    By swifty333 in forum Touran - Sharan - Caravelle
    Last Post: 30-05-2007, 09:21 PM
  3. Power Steering Fluid
    By s0niX in forum Polo - Derby - Lupo - Fox
    Last Post: 29-03-2007, 02:05 PM
  4. power steering belt adjustment
    By alan lee in forum Archive posts
    Last Post: 20-03-2007, 09:36 PM
  5. SHARAN TIMING BELT CHANGE?
    By MATT HORTON in forum Touran - Sharan - Caravelle
    Last Post: 26-11-2006, 09:16 AM
