Thread: Flat battery now fuel gauge reads empty.
Results 1 to 10 of 15
  1. Flat battery now fuel gauge reads empty.
    Aug 2008
    Wondering if any had any ideas what could be the problem and how to fix it.
    Got a flat battery and got a jump start and now the fuel gauge is reading empty and the range reads 0 miles and I know there is about 3/4 of a tank left?
    Any ideas would be a great help. Thanks Steve
  2. Re: Flat battery now fuel gauge reads empty.
    May 2007
    knee deep in clunge
    14 Post(s)
    Remove the dash fuse and refit to reboot, this has happened to myself
    2 0 0
  3. Re: Flat battery now fuel gauge reads empty.
    Aug 2008
    That worked spot cheers for that mate
    Steve
  4. Re: Flat battery now fuel gauge reads empty.
    Apr 2010
    Carms, S.Wales
    Same thing just happened to me after changing the battery, undid the fuse and re-fitted and job done.
  5. Re: Flat battery now fuel gauge reads empty.
    glasgow scotland
    Same happened to my car while in an Audi dealer getting my radio recoded. They managed to flatten the battery, then jump started it. When I complained that the fuel light was showing empty they told me I would need a new tank sender. You would think that a dealer would have known about removing the fuse. By the way that is what I did on getting home and it worked fine.
  6. Unhappy Re: Flat battery now fuel gauge reads empty.
    Aug 2011
    Sheffield uk
    Hey up - if anyone's still reading this, same problem has just happened to me - got in car completely flat, luckily was already at me mates, so we jump started it now date & time has reset & fuel gauge & anticipted mileage is "0".
    I've seen above where it says remove dash fuse, can you just confirm that its fuse "F15" which covers "instrument cluster & navigation system" (according to Haynes).
    Mick
  7. Re: Flat battery now fuel gauge reads empty.
    Sep 2011
    Shannon, Ireland
    That's the one. If I remember correctly it's 10A small fuse
  8. Re: Flat battery now fuel gauge reads empty.
    Feb 2010
    England
    Quote Originally Posted by kpn View Post
    Good grief, it's actually quite scary that a franchised dealer can be that ignorant/incompetent.
    B6 A4 2.5TDI quattro Sport (AKE)
  9. Re: Flat battery now fuel gauge reads empty.
    Aug 2011
    Hornchurch
    I have a problem very similar,
    My fuel gauge is either well past the full mark or it can just sit in any position it likes (every day is different!!) The MPG reading is well out, it was reading 140MPG yesterday. I'm unsure whether the DIS readout is correct or not but it does seem to be pretty accurate so this is how i gauge my fuel level.
    I have just tried the "reboot" and it hasn't cleared the fault, does anyone know what other problems may be causing my issue???
  10. Re: Flat battery now fuel gauge reads empty.
    Sep 2011
    Shannon, Ireland
    Fuel level sender in fuel tank
  1. possible temp gauge problem a6 2.8 quattro
    By sbt in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-06-2009, 06:54 PM
  2. Fuel gauge shows empty
    By krishcanag in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-06-2009, 08:36 AM
  3. Faulty Fuel/Temp Gauge
    By 16v_Golf in forum Archive posts
    Last Post: 24-01-2008, 01:30 PM
  4. A4 1996 Fuel gauge & Dash Lights
    By blueeye in forum Chat - Anything with wheels
    Last Post: 04-11-2007, 06:15 PM
  5. A4 1996 1.8 SE Fuel Gauge & Dash Lights
    By blueeye in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-10-2007, 03:27 PM
