Thread: T5 transporter Dual Mass flywheel problems
  1. T5 transporter Dual Mass flywheel problems
    2006 2.5 TDI transporter I just wanted to know how long a DMF should last as mine sounds like it’s on its way out clutch and flywheel were replaced by dealer under warranty about 20k ago the van is not remapped so what may have caused the flywheel to go so soon van has about 95k on the clock is there a single mass flywheel available that can be fitted
  2. Re: T5 transporter Dual Mass flywheel problems
    Oct 2009
    galsgow scotland
    ebay have a Yes- parts one piece flywheel for £169
    my T5 1.9tdi with 152k siezed but i hope it is just flywheel disintegrating
    will keep you posted
  3. Re: T5 transporter Dual Mass flywheel problems
    i have been quoted £650 for a Dual Mass flywheel and CLUTCH KIT with fitting
  4. Re: T5 transporter Dual Mass flywheel problems
    Jun 2009
    manchester, england
    Quote Originally Posted by anilkumar View Post
    see this post https://www.vwaudiforum.co.uk/forum/s...ad.php?t=79355 im in the same boat. and no i dont believe these flywheels should go as soon as the do. this guy who i know who used to work for vw rekons they had a endless flow of vws in with exactly the same problem, my brother in law had the same problem with his golf dual mass. vw should recall all vehicles with dual mass to check and replace for free as they should last a lot lot longer. not only that but when these dual mass flywheels decide to let go they smash the gearbox to little pieces
  5. Re: T5 transporter Dual Mass flywheel problems
    yes vw should do recals for this, iv strated geting vibrations though cluch pedal now so the cluctch wil neeed doing and it seems to causing 1st and reverse gear to be siff
  6. Re: T5 transporter Dual Mass flywheel problems
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Unfortunatley its an all too common problem.I worked on the VW comm.and we had to fight to get the support beams first in the workshop as we always had 1-2 boxes out per day for flywheels disintigrating/seizing-up.It was like a production line,mind you,i could get a 6 speed box out well within the hour!! Expensive to do though and i sympathise.
  1. VW Golf MK4 130bhp Dual Mass Flywheel Problems
    By Time Dependant in forum Golf MK4 - 1999 - 2004
    Last Post: 14-07-2017, 12:13 PM
  2. Dual Mass Flywheel - OE or Not OE
    By bg158a in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-11-2010, 01:30 PM
  3. Advice required on Dual Mass Flywheel - Golf 1.9 TDI MK5
    By Scoobypoo in forum Golf MK5 - 2004 - 2009
    Last Post: 10-05-2008, 12:11 AM
  4. Dual Mass Flywheel Problem
    By nickb_2008 in forum Golf MK5 - 2004 - 2009
    Last Post: 30-03-2008, 01:56 AM
  5. Dual mass flywheel problems
    By Gully in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-09-2007, 11:28 AM
