Hi, Can anyone help?
My airbag light is on and it turns out that one of the connectors to the front right hand crash sensor has been cut off! The sensor is at the back of the headlight on the driver side and is easy to spot without removing any parts.
I will order a new connector from the dealer but I was hoping someone would take a pic of the connector so I know which wire goes to which pin. I would hate to make a guess and cause the airbags to deploy!
My car is a 2003 2.5 tdi QS, but I guess any similarly aged A4 would have the same wiring?
I have Vagcom so i can clear the codes when the wiring is fixed.
Also happy to help others by using my Vagcom in the Inverness area!
Thanks, Dan.
