Thread: 1.9tdi engine surge and loss of turbo power
  1. 1.9tdi engine surge and loss of turbo power
    Sep 2009
    north wale
    Hi, kinda new on here,
    Have a problem with our 1998 a4 1.9tdi with 200k miles on it
    surges to 2500rpm when started an then doesnt have any turbo power, feels like a straight deisel. It also has a engine light on,
    does anyone have any ideas????
    Many thanks Nick
  2. Re: 1.9tdi engine surge and loss of turbo power
    Apr 2007
    Lancashire
    Hi Nick, any smoke on startup?
    Do the revs stay high, or drop straight back down?
    Does it do it on both hot and cold starts?
    Could be a number of things like a bad coolant temp sensor, or leaking injector, or too much oil getting into cylinders (turbo seals), or even fuel shutoff solenoid.
    You need to get the fault codes read to help pinpoint the problem.
  3. Re: 1.9tdi engine surge and loss of turbo power
    Sep 2009
    north wale
    No theres no smoke on start up
    revs drop to normal idle after start
    It does it on both hot and cold starts.
    Did a few searches an heard things about boost vacume pipes, and fuel pump valve.
    I know one of the vacume pipes is a little dodgy so might try sealing that up an see what else happens.
  4. Re: 1.9tdi engine surge and loss of turbo power
    Apr 2007
    Lancashire
    The loss of VNT/EGR vacuum is most likely the cause of the revs and the power loss.
  5. Re: 1.9tdi engine surge and loss of turbo power
    Apr 2010
    I have the same problem, engine blips upto 2000rpm on ingition and the drops straight back to 900rpm, there is a little blue smoke on start up but not when running. I also have circa 20% loss in power.
    What is VNT/EGR vacuum?
  1. Please Help Temporary Loss of Power at Motorway speeds
    By BenjeMK5 in forum Golf MK5 - 2004 - 2009
    Last Post: 14-08-2012, 02:04 AM
  2. loss of power
    By kaliamotors in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 14-05-2009, 05:39 PM
  3. power loss on 84 poloc when driving at speed whilst changing gear.
    By sumsoy in forum Polo - Derby - Lupo - Fox
    Last Post: 15-03-2008, 09:23 AM
  4. 1.9TDi 110 loss of power
    By jet-tech in forum Archive posts
    Last Post: 28-09-2007, 03:58 PM
  5. Golf 1.4 cl MK3 Engine Kangaroos!!
    By stusav369 in forum Golf MK3 - 1993 - 1999
    Last Post: 19-03-2007, 06:32 PM
