Thread: Drivers door locking mechanism not working properly
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: Drivers door locking mechanism not working properly
    Dec 2007
    I doubt that the lock is faulty the part that fails is integral to the door lock mechanism, If a new part has been put in then i doubt that the microswitch is the problem, also if you have had the fault code scanned and nothing shows up the lock is probably all ok.
    Have you looked at the cable that attaches the external door handle this may still be the answer even though hitting the door does not work. If this is too tight then this may be the problem. The only real way to tell is to slacken it and see if this solvs the problem
  2. Re: Drivers door locking mechanism not working properly
    Dec 2007
    See cable in picabove (yellow arrow) you do not need to remove the lock to adjust this just pull handle open
  3. Re: Drivers door locking mechanism not working properly
    Aug 2007
    Quote Originally Posted by GRaymond View Post
    I had a look at that pic, and it's the drivers side so has the key hole there.
  4. Re: Drivers door locking mechanism not working properly
    Dec 2007
    Just pull the handle and hold in the open position and you should see the cable. There is no need to remove the lock barrel
  1. Replies: 7
    Last Post: 17-09-2017, 08:01 PM
  2. Replies: 2
    Last Post: 17-08-2010, 10:37 AM
  3. Please Help 2.0l GTi Drivers Window Not Working
    By svenandnancy in forum Golf MK3 - 1993 - 1999
    Last Post: 14-07-2009, 12:02 AM
  4. Please Help Driver's door central locking not working
    By eytch in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-05-2009, 11:31 PM
  5. "How To" The FAQ & How To Thread
    By Ben in forum General
