Thread: Check Brake Pads Warning
  1. Check Brake Pads Warning
    Oct 2005
    Yesterday I changed the front brake pads on my Passat V6 4Motion, now when I start the car the onboard computer beeps and tells me to check the brake pads. Does any one know why this is please?
    7 Post(s)
    Either;
    The new pads you have fitted have faulty sensor wires.
    or
    There is a loose connection between the new pads and the cars loom.
    I'd double check everything, unplug the sensors and make them closed circuit (bridge the terminals) to elinate things on the car side of the circuit. Then test for continuity through the pad sensors.
  3. Resolved Thanks
    Oct 2005
    Thanks for help with this I did exactly as you described to no avail, however I sprayed the inside of the connectors with contact cleaner and this resolved the issue. Thanks for your help on this, without which I would have taken an age to fix. Cheers.
  1. Changing Brake Pads
    By jimbo73 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-10-2008, 09:38 PM
  2. Golf mk4 brake pads
    By tixy in forum Golf MK4 - 1999 - 2004
    Last Post: 07-05-2007, 11:15 AM
  3. Brake pads
    By k3t4n in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-04-2007, 04:33 PM
  4. Front brake pads that never wear out!!
    By Matt B in forum Chat - Anything with wheels
    Last Post: 29-03-2007, 03:12 PM
  5. A6 Brake Pads
    By DWT in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-01-2007, 06:05 PM
