Thread: Boost pressure Sensor
  1. Boost pressure Sensor
    Sep 2009
    Bebington Wirral
    can anybody tell me where the boost pressure sensor is located on a MK5 golf??
  2. Re: Boost pressure Sensor
    Sep 2009
    London
    Hi there, not sure if this will help as it is to do with another car, god knows what type but here it goes.
    the texts you see was with pictures but pictures are not needed as it is another car, might give you an idea where to look.
    Locate the Fuel Pressure Sensor located on the fuel rail just behind the intake manifold pipe. This sensor is directly below the engine oil dip-stick tube and mounted in the high pressure fuel rail
    Locate the boost pressure sensor. It is located just behind and to the left of the fuel pressure sensor.
    Also there is this but it only says pressure sensor.
    http://forums.tdiclub.com/showthread...155230&page=14
  3. Re: Boost pressure Sensor
    Sep 2009
    England
    Boost pressure sensor is located in the plastic intake pipe leading up to the inlet manifold - It will have a 4 pin connector attched to it.
  1. ABS Sensor: ABSolute pain!
    By tornadored7 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-11-2009, 04:04 PM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. Boost Pressure Sensor - need help with wiring
    By turbobugger in forum Beetle 2000-
    Last Post: 17-04-2008, 06:26 AM
  4. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
  5. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
