Thread: golf tdi judders when coming to a stop
  1. golf tdi judders when coming to a stop
    May 2007
    I own a 99 golf tdi, I have a problem, when I start slowing down to come to a stop, the car judders, making a tick tick noise, and then when I stop it goes quiet again. I wondered if this could be a mass airflow problem.
    Another problem I have is when on a motorway, and I reach 70mph, I suddenly lose power, with acceleration drastically reduced, then when I pull off the motorway, the car performs really slowly.
    When leaving the car for half an hour or so, and restarting full power has returned again.
    I have new plugs and a fuel filter fitted but no change, also I have noticed that I can't hear the turbo whistling noise like I used too.
    Any help on either problem would be appreciated, thanks
  2. Re: golf tdi judders when coming to a stop
    Jul 2009
    Aberlour, scotland
    Sounds like the car has gone into "limp home" mode. Best idea would be to get it plugged onto a vagcom or suchlikes.
    You have said that the car has had new plugs... This cannot be the case, your car is a diesel!
  3. Re: golf tdi judders when coming to a stop
    May 2007
    glow plugs i mean
  4. Re: golf tdi judders when coming to a stop
    Sep 2009
    England
    You have 2 different faults here - The first one with juddering when coming to a stop is cause by faulty software in the engine ECU, it's a known problem, unfortunalty the software is unable to be updated so a replacement is needed. The 2nd fault sounds like a turbo overboost condition. The ECU is shutting turbo control off to avoid damage to the engine, Do you find that if you cycle the ignition you have full power again?
  1. Replies: 0
    Last Post: 15-08-2009, 07:48 PM
  2. Golf TDI 90/110bhp engine query
    By william200mph in forum Golf MK3 - 1993 - 1999
    Last Post: 04-04-2008, 02:18 PM
  3. First Facts on the Golf BlueMotion:
    Last Post: 13-08-2007, 07:08 PM
  4. Golf GT TDI or Upgrade the Passat V6TDI
    By LWW in forum Chat - Completely Off Topic
    Last Post: 30-10-2006, 08:50 PM
  5. 24 MILLIONTH GOLF ROLLS OFF LINE - EXPANDED UK GOLF RANGE
