Thread: Speaker Grill Nightmare!
  1. Unhappy Speaker Grill Nightmare!
    Aug 2009
    Hockley England
    Speaker Grill Problem.
    Can anybody help? New Forum Member asks if anybody knows how to replace a nearside front speaker grill on my 2006 A4 Avant S-line? Guy in the dealership said he would have charge a couple of hours for doing it. He also told me I would have to take the whole inside door panel off, seems a bit drastic but what do I know? Buy the most helpful person a few beers.
    David
  2. Re: Speaker Grill Nightmare!
    May 2007
    knee deep in clunge
    14 Post(s)
    Remove the door trim.Carefully drill the plastic weld points to remove the speaker then fit the new speaker cover and re bond with glue or remelt with a heat gun.Time 1 hour
  3. Re: Speaker Grill Nightmare!
    Aug 2007
    Newport, Wales
    7 Post(s)
    Yup.. I did it on a previous A4..
    You do have to take the whole door trim off, but that's a quick job.. just a case of undoing some bolts and pulling the door trim away from its pop-mounts.
    If you are a handy fella and can do tha majority of DIY, have a go, it's not a difficult job.
    As A8 Tech says, you'll need to drill-out the plastic weld points for the old speaker.
    As you melt each plastic legs of the new speaker grille; continually check that the grille is pushed back into the door trim as far as it'll go. If you don't, you'll find that it'll be slightly loose when you've finished & may rattle / resonate when music played through it!
    By the way, to melt the plastic legs, I used a screw-driver heated over a gas hob! Crude & smelly, but it worked!
    Al.
    [ My Cars: 2011 Caravelle SE TDI (140) LWB | 2015 L200 Barbarian 2.4 DI-D | 2015 Mini Cooper SD ]
    [ Past Audis:
    A6 S-Line 3.0
    V6 TDI Qttr | A4 3.0 TDI Qttr S-Line | S6 4.2 Qttr | A4 2.5 V6 TDI Qttr Sport | A4 1.9 TDI Qttr S-Line | A4 SE 2.0 TFSI Quattro Avant | 2.0 TFSI Roadster ]
    [ Past VWs: Mk1 GTI Cab | Mk3 2.0 Cab |
    Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Golf 1.9 TDI| Mk4 Supercharged 2.0 6-speed | VW Touran 2.0 TDI DSG ]
  1. HELP NEEDED:- 54 Reg Split Grill to Big Grill Conversion
    By craig2210 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 26-02-2011, 03:03 AM
  2. Question VW Golf 1.4S Rear Speaker Covers?
    By ImCammers in forum Golf MK4 - 1999 - 2004
    Last Post: 09-05-2009, 12:33 PM
  3. Please Help Drivers side speaker - door card removal.
    By revo_20vt in forum Audi A3 - Archive Topics
    Last Post: 13-05-2008, 11:40 AM
  4. Passat Grill
    By Touchofclass in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-05-2008, 01:23 PM
  5. Quiet Speaker
    By coeur in forum Golf MK4 - 1999 - 2004
    Last Post: 15-10-2007, 03:47 PM
