Thread: Vag 5053
  1. Vag 5053
    Aug 2009
    fife
    Is the VAG5053 any good?
    I'm looking for a "cheap" code reader so I don't have to go the a garage to get a code read every time something goes wrong. I would like to be able to read the code in the first instance and then take it to a garage depending on the fault.
    I'm looking for a reader that will work with my 52 plate passat tdi and my 54 plate golf tdi and was wondering if the VAG5053 would do the trick. I'm not looking for an all singing and dancing reader, just one that does the job and ideally doesn't need to be connected to a PC/laptop, except for updates.
    I found the VAG5053 on ebay for around £65 new. Is that a reasonable price?
    http://cgi.ebay.co.uk/VAG-5053-DIAGN...QQcmdZViewItem
    Thanks in advance for any advice or alternative suggestions.
  2. Re: Vag 5053
    Nov 2008
    folkestone.kent
    looks like it should do the job
  3. Re: Vag 5053
    Aug 2009
    fife
    Thanks.
    After some replies to other posts, i'm going to go down the vagcom route (shareware version) with a usb cable and laptop.
    Might still go for a handheld reader at a later stage though. The 5053 would seem to be suitable for my 52 passat but not the 54 golf.
  1. VAG 5053 Handheld scanner
    By vr6280 in forum VCDS - General Questions
    Last Post: 09-09-2009, 07:47 PM
  2. VAG 5053 diagnostic tool
    By AJC2008 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-09-2009, 10:09 PM
  3. VAG 5053 scanner in Crawley, West Sussex
    By lucianus in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 16-04-2009, 12:38 AM
  4. VW/Audi CAN BUS VAG 5053
    By skodaman in forum Octavia
    Last Post: 17-08-2008, 05:33 PM
  5. Are And Vag Com / Vag Tacho The Same
    By davecoz in forum VCDS - General Questions
    Last Post: 21-11-2007, 09:13 AM
