Thread: codes
Results 1 to 8 of 8
  1. codes
    Jun 2009
    uk
    put my Audi a4 1.9 tdi on me m8s vag and come up with the following error codes.
    17965 - Charge Pressure Control: Positive Deviation P1557 - 35-10 - - - Intermittent.
    What might this refer to?
    The car has been smoking intermittently and will run into over boost limp if pushed hard.
    17994/P1586/005510 - Engine Mount Solenoid Valves (N144/N145): Short to Plus Intermittent.
    Any ideas where exactly this N144/N145 is exactly ?
    been reading on wiki and we have chceked the hoses and they look fine.
    will chainging the solonoid fix this problem??
  2. Re: codes
    Jun 2009
    uk
    anyone plz.
  3. Re: codes
    Ambler, PA, USA
  4. Re: codes
    Jun 2009
    uk
    hi
    thank for reply but my mechanic has checked the pipes and hoses and said they are ok.
    i know the turbo needs fixing as its got soot built up but the solonoid problem my mechanic dont know how to fix this problem does the solonoid valves need changeing.
    thanks
  5. Re: codes
    Nov 2008
    N/A
    I had the 1st one on my MkIV Golf for 3 years - never affected anything, it was because of the remap I was told. (And probably a hefty bit of right foot)
  6. Re: codes
    Jun 2009
    uk
    yeah but mines goes into limp mode at times like once a month.
  7. Re: codes
    Nov 2008
    N/A
    Does it go into limp mode at 4000rpm or just above? Or nearer 2500rpm?
  8. Re: codes
    Jun 2009
    uk
    when im doing about 50mph somtimes it goes into limp mode speed stays at 40mph with full foot down.
  1. alarm fault codes
    By A6TYY in forum VCDS - Help Requests
    Last Post: 17-08-2009, 08:01 PM
  2. Please Help MIL Warning Codes - faulty sensor?
    By Andrew Pawsey in forum Ibiza - Cordoba
    Last Post: 08-05-2008, 09:06 PM
  3. help w/error codes, 99 2.0L Jetta
    By vwfreak73 in forum Golf MK3 - 1993 - 1999
    Last Post: 03-03-2008, 07:15 PM
  4. Why do these OBDII / DTC Fault codes keep coming back ?
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-11-2007, 07:01 PM
  5. mk4 gti 2.0, 3 error codes, lean trim, ideas?
    By leckford in forum Golf MK4 - 1999 - 2004
    Last Post: 24-05-2007, 11:57 PM
