Thread: 17965 - Charge Pressure Control: Positive Deviation
  1. 17965 - Charge Pressure Control: Positive Deviation
    Aug 2007
    Northern Ireland
    Car (2002 Golf GT TDI 130PD) went into limp mode last night on the way home (been fine since I got home and stopped/restarted)
    Got the vagcom out and found "17965 - Charge Pressure Control: Positive Deviation " logged
    I have taken the car out this evening and logged a few data fields for the purpose of faultfinding, I have uploaded the log below
    http://www.bbjunkie.f2s.com/log.csv
    I'm not great with excel, so can't graph it.. however it is plain to see from the numbers that at times the boost is around 2980mb which equates to 43psi (28psi over atmospheric)
    Not sure how boost pressure is measured, but I would've thought that either 43psi OR even 28psi is dangerously high, am I right?
    Any pointers to sorting this out appreciated..
    Pete
    52 plate Golf GT TDi
  2. Re: 17965 - Charge Pressure Control: Positive Deviation
    nottinghamshire
    Quote Originally Posted by mobitune View Post
    Pete
    i have the same over boost problem
    its from the turbo being stuck in maximum boost, i think it all starts from the EGR valve.
    you can strip and clean the turbo or buy a new one
    if you want to strip and clean the turbo there are loads of instruction on how to do it, just use the search option in this forum
    hope this helps
  3. Re: 17965 - Charge Pressure Control: Positive Deviation
    Dec 2007
    New Mills, Derbyshire
    Try the Innoitec Turbo Clean kit... it worked for me.
    http://www.innotecworld.com/c-1064-turbo-clean-set.aspx
    When using it, you will need something to make the cardboard 'blank' seal to the turbo to stop the 'gunk' leaking out. The instructions say use the old gasket, but this still isnt upto the job. Something more sturdy is required.
    150 GTI DIESEL - propper juice!!
  4. Re: 17965 - Charge Pressure Control: Positive Deviation
    nottinghamshire
    Quote Originally Posted by M53494 View Post
    how much is that stuff
  5. Re: 17965 - Charge Pressure Control: Positive Deviation
    Dec 2007
    Give or take a few pence, when I bought it, it was £37 inc delivery, direct from Innotec.
    There are a fet threads on here about it. Do a search for 'Innotec'.
  6. Re: 17965 - Charge Pressure Control: Positive Deviation
    Aug 2007
    Northern Ireland
    Thanks guys, I had a sneaking suspicion that it was going to be the Variable Geometry turbo giving the trouble, just was kind of hoping it wasn't!
    How long after application of the innotek product do you need to reapply?
    Pete
  1. Fault cold 00575
    By tazzie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-05-2009, 06:32 PM
  2. auto shutdown of convenience systems
    By bigb in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 29-03-2009, 07:40 PM
  3. 17958 - Charge Pressure: Control Deviation
    By andy1max in forum Golf MK4 - 1999 - 2004
    Last Post: 15-05-2008, 08:39 PM
  4. Charge Pressure deviation sporadic
    By Eugheugh in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-07-2007, 08:49 PM
