Thread: Battery warning light????
  1. Battery warning light????
    Hi every1, i havent been on the forum for a while, but i am in need of a bit of help, please.
    A battery light has just started flashing on the dash of my 2004 sharan with the words "Alternator Workshop".
    Does anyone have any ideas of what this could be please.
    All replies are gratefully received, thanks.
  2. Re: Battery warning light????
    Jan 2009
    towcester northants
    is the pas noisy on lock?
    2 things it could be
    1 check charge rate must be about 14v
    2 remove the pas/alt belt and check the freewheel pulley to see if seized this is the reason i asked if the pas was noisy
    the most common fault is the pulley
  3. Re: Battery warning light????
    hi there, the charge rate is fine. Come to mention about some noises, i have heard the odd noise coming from the alternator. If the pulley has seized, can it be changed or does it mean a new alternator, thanks.
  4. Re: Battery warning light????
    Jan 2009
    towcester northants
    the pulley can be changed
    there is a special tool for doing this though
    gsf and euro car parts do the pulley but there are several types so they will need the alternator number to get right
  5. Re: Battery warning light????
    Thanks towcestervag, that has helped alot.
  6. Re: Battery warning light????
    Oct 2009
    stoke england
    Hi, Prob a bit late but iv'e just had this problem. The wiring multi plug behind the battery was full of water and gundge. ! Clean it out an dry,worked fine.
  1. How To DIS AND CRUISE RETRO FIT b6+b7
  2. HID Aftermarket kits - Not Legal....
    By RickT in forum Chat - Anything with wheels
    Last Post: 13-05-2011, 12:44 PM
  3. Rear fog light / reverse light fault (golf 5)
    By 85turbo in forum VCDS - General Questions
    Last Post: 03-09-2010, 11:30 PM
  4. Question engine warning light and battery
    By Bill Tracey in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-05-2009, 03:58 PM
  5. A4 2002 Brake Pad Warning Light (0)
    By mandilou in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-03-2008, 06:18 PM
